Modify a certificate
Modifies a certificate, updating the trust store to reflect changes in the certificate's status or content. Use this endpoint to ensure the trust store accurately represents trusted and untrusted certificates.
HTTP method and endpoint
PUT /accounts/{account_id}/core/v1/certificates/{certificate_id}
Usage notes
Replaces the entire stored resource with the supplied JSON request body.
Side Effects
An updated CA certificate will be updated in the trust store.
If an existing trusted CA certificate becomes untrusted, it will be removed from the trust store.
If a certificate body is updated ("cert" field), the "isSelfSigned" indicator must be included to indicate the state of the new certificate. If the "isSelfSigned" indicator is not included in this case, the value will be set to "false".
If an update does not modify the certificate body ("cert" field), the "isSelfSigned" indicator is optional and the existing value will be retained if not provided.
account_id |
string |
path |
True |
certificate_id |
string |
path |
True |
ID of the certificate collection to list |
Request Body
Side Effects
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
certUse |
string |
False |
JSON string indicating the use of the certificate. If not specified, defaults to "rootCA". Defined values are:
cert |
string |
False |
JSON string containing a base64 encoded PKCS-11 formatted certificate (PEM). Defined values are:
cn |
string |
False |
JSON string containing a common name extracted from the certificate. Defined values are:
expiryTimestamp |
string |
False |
JSON string containing a timestamp indicating when the certificate expires. Defined values are:
isSelfSigned |
string |
False |
JSON string indicating whether the certificate is self-signed. If not provided on create, the value defaults to "false". On update:
trustState |
string |
False |
JSON string containing one of a set of enumerated values indicating whether the certificate is trusted. Defined values are:
trustStateTransitions |
array[type_astra_stateTransition] |
False |
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state, and the "to" value is an array of permitted destination states. |
trustStateDesired |
string |
False |
JSON string containing a value indicating whether the certificate is trusted. If not specified on create, the default value is "trusted". Defined values are:
trustStateDetails |
array[type_astra_stateDetail] |
False |
JSON array of JSON objects that lists additional details about the trust state of the certificate. If no details are available, this array will be empty.
metadata |
False |
Example request
"type": "application/astra-certificate",
"version": "1.1",
"trustStateDesired": "trusted"
Status: 204, Indicates if the certificate resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 503, Service unavailable
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/41",
"title": "Service not ready",
"detail": "Currently, the service can't respond to this request.",
"status": "503"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
from |
string |
True |
to |
array[string] |
True |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
