Modify a hook source
Modifies a hook source in Astra API. You might use this endpoint to update the source code for execution hooks associated with application snapshots.
HTTP method and endpoint
PUT /accounts/{account_id}/core/v1/hookSources/{hookSource_id}
Usage notes
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
Updating an existing source hook will immediately impact any future snapshots of applications that have matching execution hooks that use the updated source hook resource.
The MD5 checksum is computed on the value of the "source" field and set as the value of the "sourceMD5Checksum" field.
account_id |
string |
path |
True |
hookSource_id |
string |
path |
True |
ID of the hookSource collection to list |
Request Body
Side Effects
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
name |
string |
False |
JSON string containing a user-specified name for the resource. Defined values are:
private |
string |
False |
JSON string indicating whether the source field will be exposed in APIs or be intentionally left blank. Defined values are:
preloaded |
string |
False |
JSON string that indicates whether the source was preloaded. Defined values are:
sourceType |
string |
False |
JSON string defining the hook source type. Defined values are:
source |
string |
False |
JSON string containing the script to be run in base64 format. Defined values are:
sourceMD5Checksum |
string |
False |
JSON string containing the MD5 checksum computed for the value of the "source" key. Defined values are:
description |
string |
False |
JSON string containing a user-specified description of the hook source. Defined values are:
metadata |
False |
Example request
"type": "application/astra-hookSource",
"version": "1.0",
"source": "ZWNobyAiVkhKaGJuTWdVbWxuYUhSeklRPT0iIHwgYmFzZTY0IC1k",
"description": "Pre and post hook script for order processing v2"
Status: 204, Indicates if the hookSource resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
