Astra Automation
Modify a license
Modifies a license resource by replacing the stored data with the supplied information while preserving certain key values. You might use this endpoint to update license entitlements efficiently.
HTTP method and endpoint
PUT /accounts/{account_id}/core/v1/licenses/{license_id}
Usage notes
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
  • Entitlements are recalculated to add or merge the license entitlements visible through the Entitlement API.
account_id
string
path
True
  • example: {{.Account}}
license_id
string
path
True
ID of the license collection to list
Request Body
Side Effects
type
string
True
  • "application/astra-license"
version
string
True
  • "1.0"
id
string
False
allocation
string
False
JSON string containing an ID indicating what the license is allocated to. Only present when the license is allocated. For Astra Control Center licenses, this field must be populated with the account ID and must match the account ID specified in the POST URI. Defined values are:
  • Conforms to the Astra Identifier Schema
hostID
string
False
JSON string containing a host identifier that a license is bound to. Only present if the license is host-locked. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
deviceCredentialID
string
False
JSON string containing the identifier of the deviceCredential associated with the Credential API. Only present for Astra Data Store licenses. Defined value are:
isEvaluation
string
False
JSON string indicating whether the license is an evaluation license. Defined values are:
  • "true"
  • "false"
licenseProtocol
string
False
JSON string containing the license protocol extracted from the license. Defined values are:
  • String contents not validated by the schema
licenseText
string
False
JSON string containing a base64 encoded representation of the license JSON as obtained from the NetApp license system. This must be provided in the original byte-level order to allow signature verification. Defined values are:
  • Conforms to the base64 Encoded Data Schema
validFromTimestamp
string
False
JSON string containing a timestamp indicating when the license becomes valid. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
validUntilTimestamp
string
False
JSON string containing a timestamp indicating when the license is no longer valid. Defined values are:
product
string
False
JSON string containing the product string extracted from the license. Defined values are:
productVersion
string
False
JSON string containing the version string extracted from the license. Defined values are:
productSN
string
False
JSON string containing the serial number string extracted from the license. Defined values are:
features
string
False
JSON string containing the package value extracted from the license. Defined values are:
capacity
string
False
JSON string containing the capacity extracted from the license.
capacity2
string
False
JSON string containing the secondary capacity extracted from the license.
addons
array[addons]
False
JSON array of JSON objects containing the list of add-ons from the license. An add-on is a change in license occurring at a potential future date.
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-license",
  "version": "1.0",
  "allocation": "4185d09b-6687-4801-a832-c005a9d94f41",
  "licenseText": "ewogICAic3RhdHVzUmVzcCI6ewogMTYwNzAwIgp9"
Status: 204, Indicates if the license resource was updated.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
addons
startDate
string
False
JSON string containing a timestamp indicating when this add-on becomes valid. Defined values are:
endDate
string
False
JSON string containing a timestamp indicating when this add-on is no longer valid. Defined values are:
features
string
False
JSON string containing the list of features associated with this add-on. Defined values are:
  • String contents not validated by the schema.
capacity
string
False
JSON string containing the capacity extracted from the add-on. Defined values are:
licenseProtocol
string
False
JSON string containing the license protocol associated with this add-on. Defined values are:
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
modificationTimestamp
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
