Modify an execution hook for an app
Modifies an execution hook for an app, affecting future application actions that utilize the updated hook.
HTTP method and endpoint
PUT /accounts/{account_id}/k8s/v1/apps/{app_id}/executionHooks/{executionHook_id}
Usage notes
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
Updating an existing execution hook will impact any future actions of applications that use the updated execution hook.
account_id |
string |
path |
True |
app_id |
string |
path |
True |
ID of the containing app resource |
executionHook_id |
string |
path |
True |
ID of the executionHook collection to list |
Request Body
Side Effects
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
name |
string |
False |
JSON string containing a user-specified name for the resource. Defined values are:
hookType |
string |
False |
JSON string defining the hook type. Defined values are:
matchingCriteria |
array[matchingCriteria] |
False |
JSON array of JSON objects describing the match criteria for the execution hook. When multiple matchingCriteria are specified a logical AND is applied to criteria. Defined values are:
action |
string |
False |
JSON string indicating which action the execution hook will run assuming the match criteria are met. Defined values are:
stage |
string |
False |
JSON string indicating the stage during the action that the hook will be executed. Defined values are:
hookSourceID |
string |
False |
JSON string containing the hook source ID that is run through this execution hook. Defined values are:
arguments |
array[string] |
False |
JSON array of JSON strings for the arguments to the source. Defined values are:
appID |
string |
False |
JSON string containing the associated ID of the application that this hook is linked to. In essence, other matching criteria, if set. Defined values are:
enabled |
string |
False |
JSON string that indicates if the execution hook is enabled. Defined values are:
description |
string |
False |
JSON string containing a user-specified description for the hook source. Defined values are:
metadata |
False |
Example request
"type": "application/astra-executionHook",
"version": "1.2",
"arguments": [
"freeze",
"10"
Status: 204, Indicates if the executionHook resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
matchingCriteria
type |
string |
False |
JSON string identifying the match criteria type. |
value |
string |
False |
JSON string containing a regex to match for the given match type. Regex syntax: https://github.com/google/re2/wiki/Syntax |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
