Modify a bucket
Modifies a bucket by updating its stored resource with the provided JSON request body, while preserving essential key values. Use this to ensure the bucket's configuration reflects your desired settings while maintaining system integrity.
HTTP method and endpoint
PUT /accounts/{account_id}/topology/v1/buckets/{bucket_id}
Usage notes
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
account_id |
string |
path |
True |
bucket_id |
string |
path |
True |
ID of the bucket collection to list |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
name |
string |
False |
JSON string containing a user-assigned name for the bucket. Defined values are:
credentialID |
string |
False |
JSON string containing the identifier of the credentials used to access the bucket. Defined values are:
state |
string |
False |
JSON string containing a value indicating the operational state of the bucket. Defined values are:
stateDetails |
array[type_astra_stateDetail] |
False |
JSON array of JSON objects that lists additional details about why "state" transitioned to "removed" or "failed". If no details are available, this array will be empty.
provider |
string |
False |
JSON string indicating the bucket protocol that can be used to access the bucket. Defined values are:
bucketParameters |
False |
JSON object that provides bucket provider-specific information required to access the bucket. The specific values in this bucket vary per provider. |
metadata |
False |
Example request
"type": "application/astra-bucket",
"version": "1.2",
"name": "New Bucket Name"
Status: 204, Indicates if the bucket resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
type |
string |
True |
title |
string |
True |
detail |
string |
True |
s3
JSON object that provides Simple Storage Service (S3) protocol parameters. (Use this object for all S3 type providers).
serverURL |
string |
False |
JSON string containing a URL to the base path for the bucket. Defined values are:
bucketName |
string |
False |
JSON string containing the name of the S3 bucket. Defined values are:
gcp
JSON object that provides Google Cloud protocol parameters.
bucketName |
string |
False |
JSON string containing the name of the backing Google Cloud bucket name. Defined values are:
azure
JSON object that provides Azure protocol parameters.
storageAccount |
string |
False |
JSON string containing the Azure storage account name. Defined values are:
bucketName |
string |
False |
JSON string containing the name of the backing Azure blob name. Defined values are:
bucketParameters
s3 |
False |
JSON object that provides Simple Storage Service (S3) protocol parameters. (Use this object for all S3 type providers). |
gcp |
False |
JSON object that provides Google Cloud protocol parameters. |
azure |
False |
JSON object that provides Azure protocol parameters. |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
