Astra Automation
Add a cluster using credentials
Contributors dmp-netapp
You can add a cluster so it will be available to be managed by Astra. Beginning with the Astra 22.11 release, you can add a cluster with both Astra Control Center and Astra Control Service.
Note Adding a cluster is not required when using a Kubernetes service from one of the major cloud providers (AKS, EKS, GKE).
1. Obtain the kubeconfig file
You need to obtain a copy of the kubconfig file from your Kubernetes administrator or service.
2. Prepare the kubeconfig file
Before using the kubeconfig file, you should perform the following operations:
Convert file from YAML format to JSON
If you receive the kubeconfig file formatted as YAML, you need to convert it to JSON.
Encode JSON in base64
You must encode the JSON file in base64.
Example
Here is an example of converting the kubeconfig file from YAML to JSON and then encoding it in base64:
yq -o=json ~/.kube/config | base64
3. Select the cloud
Perform the workflow List the clouds and select the cloud where the cluster will be added.
Note The only cloud you can select is the private cloud.
4. Create a credential
Perform the following REST API call to create a credential using the kubeconfig file.
HTTP method Path
POST
/accounts/{account_id}/core/v1/credentials
JSON input example
  "type" :  "application/astra-credential",
  "version" : "1.1",
  "name" : "Cloud One",
  "keyType" : "kubeconfig",
  "keyStore" : {
    "base64": encoded_kubeconfig
  "valid" : "true"
Curl example
curl --location -i --request POST 'https://astra.netapp.io/accounts/<ACCOUNT_ID>/core/v1/credentials' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>' --data @JSONinput
5. Add the cluster
Perform the following REST API call to add the cluster to the cloud. The value of the credentialID input field is obtained from the REST API call in the previous step.
HTTP method Path
POST
/accounts/{account_id}/topology/v1/clouds/{cloud_id}/clusters
JSON input example
  "type" :  "application/astra-cluster",
  "version" : "1.1",
  "credentialID": credential_id
Curl example
curl --location -i --request POST 'https://astra.netapp.io/accounts/<ACCOUNT_ID>/topology/v1/clouds/<CLOUD_ID>/clusters' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>' --data @JSONinput
