Delete an app for a managed cluster
DELETE /accounts/{account_id}/topology/v2/managedClusters/{managedCluster_id}/apps/{app_id}
Removes the specified App API resource.
Side Effects
If the application is still running on a cluster, the application is no longer considered to be under management and will no longer appear under /apps.
First, the application goes into the deleting state and then deletes all associated schedules, snapshots, backups, and the stored application state.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
managedCluster_id |
string |
path |
True |
ID of the containing managedCluster resource |
app_id |
string |
path |
True |
ID of the app collection to list |
Status: 204, Indicates if the app resource was deleted.
Status: 401, Unauthorized
Name | Type | Required | Description |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/91",
"title": "Application not deleted",
"detail": "The application wasn't deleted because of an internal server issue.",
"status": "500"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/112",
"title": "Application not ready",
"detail": "The application is currently unavailable.",
"status": "409"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
