Retrieve an ASUP resource
Retrieves an ASUP resource, allowing access to the stored AutoSupport data for monitoring and diagnostic purposes.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/asups/{asup_id}
Usage notes
Returns the stored ASUP API resource in the JSON response body. If the AutoSupport bundle "creationState" is "completed" or "partial", the AutoSupport bundle can be downloaded by specifying an Accept header containing "/" or "application/gzip".
account_id |
string |
path |
True |
asup_id |
string |
path |
True |
ID of the asup collection to list |
Status: 200, Returns the stored ASUP API resource in the JSON response body. If the AutoSupport bundle "creationState" is "completed" or "partial", the AutoSupport bundle can be downloaded by specifying an Accept header containing "*/*" or "application/gzip".
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
creationState |
string |
True |
JSON string containing a value indicating the creation state of the AutoSupport bundle. For "completed" and "partial" states, the bundle can be downloaded by performing a GET of the resource URI with an Accept header containing "/" or "application/gzip". Defined values are:
creationStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about why "creationState" transitioned into "partial" or "failed". If no details are available, this array will be empty.
upload |
string |
True |
JSON string containing a value indicating whether to upload the AutoSupport bundle after successful creation. Defined values are:
uploadState |
string |
False |
JSON string containing a value that indicates the state of the AutoSupport bundle upload if it was requested. Defined values are:
uploadStateDetails |
False |
JSON array of JSON objects that lists additional details about why "uploadState" transitioned into "failed". If no details are available, this array will be empty.
triggerType |
string |
True |
JSON string containing a value that indicates what triggered the creation of the ASUP resource. Defined values are:
dataWindowStart |
string |
True |
JSON string containing a timestamp indicating the start time of the AutoSupport bundle data collection window. Defaults to 24 hours before the "dataWindowEnd" key value. Must occur before the "dataWindowEnd" key value. Maximum is 7 days before the current time of the request. Defined values are:
dataWindowEnd |
string |
True |
JSON string containing a timestamp indicating the end time of the AutoSupport bundle data collection window. Defaults to the current time of the request. Defined values are:
metadata |
True |
"type": "application/astra-asup",
"version": "1.0",
"id": "9950003f-a1c7-5ca7-8930-06eec25f60aa",
"creationState": "completed",
"creationStateDetails": [],
"upload": "false",
"triggerType": "manual",
"dataWindowStart": "2020-08-05T12:24:00.000000Z",
"dataWindowEnd": "2020-08-06T12:24:52.000000Z",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
additionalDetails
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
