Retrieve an LDAP group
GET /accounts/{account_id}/core/v1/ldapGroups/{ldapGroup_id}
Returns a JSON object representing the stored LDAP resource.
account_id
string
path
True
  • example: {{.Account}}
ldapGroup_id
string
path
True
ID of the ldapGroup collection to list
Status: 200, Returns a JSON object representing the stored LDAP resource.
type
string
True
  • "application/astra-ldapGroup"
version
string
True
  • "1.0"
id
string
True
cn
string
False
JSON string representing the LDAP group name. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
dn
string
False
JSON string representing the distinguished name of the LDAP group. Defined values are:
  • Conforms to RFC 4514
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-ldapGroup",
  "version": "1.0",
  "id": "cb05a289-a7a1-502c-a2bc-7e75dba8fddc",
  "cn": "boulder_sysadmins",
  "dn": "cn=boulder_sysadmins,ou=groups,dc=example,dc=com",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
