Retrieve a setting
GET /accounts/{account_id}/core/v1/settings/{setting_id}
Returns the stored Setting API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
setting_id
string
path
True
ID of the setting collection to list
Status: 200, Returns the stored Setting API resource in the JSON response body.
type
string
True
  • "application/astra-setting"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
JSON string containing a name for the setting, in hierarchal dot notation (.). Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks. This value is specified by the configmap that is loaded at runtime and cannot be updated by the user.
currentConfig
type_json
True
JSON object containing keys and values that make up the current configuration for this setting. The contents of this object must conform to the JSON Schema contained in the configSchema field. Default values are supplied by the configmap. After defaults are changed by the user, they will not be overwritten.
desiredConfig
type_json
False
JSON object containing keys and values that make up the requested configuration for this setting. The contents of this object must conform to the JSON schema contained in the configSchema field. The object does not exist until specified. When specified, this triggers the feature service to notify the corresponding service to request that the desired configuration can be applied. The corresponding service can then perform validation and apply the desired configuration to the current configuration.
configSchema
type_json_schema
True
JSON object containing the JSON schema for the config property in this resource. Must conform to JSON Schema Draft 7. If config values are present in the resource, validation against the indicated configSchema is mandatory. As a common convention, configurations are recommended to have an "isEnabled" field, when appropriate. The "isEnabled" field contains a value that indicates whether the setting is turned on ("true") or off ("false").
state
string
True
JSON string containing a value indicating the operational state of the application. Defined values are:
  • "valid" - The current configuration matches the desired config.
  • "pending" - The desired configuration is being applied.
  • "error" - The desired configuration cannot be applied.
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why the setting was not successfully applied. Defined values are:
  • Minimum length: 1
  • Maximum length: 127
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-setting",
  "version": "1.1",
  "id": "ea510866-47d3-5130-8468-563df4cd6a28",
  "name": "astra.account.smtp",
  "currentConfig": {
    "credential": "",
    "isEnabled": "false",
    "port": 587,
    "relayServer": "smtp.sendgrid.net"
  "configSchema": {
    "$schema": "http://json-schema.org/draft-07/schema#",
    "title": "astra.account.smtp",
    "type": "object",
    "properties": {
      "credential": {
        "type": "string",
        "description": "The credential ID for SMTP authentication."
      "isEnabled": {
        "type": "string",
        "description": "This property determines if this setting is enabled or not."
      "port": {
        "type": "integer",
        "description": "The SMTP port. For an unencrypted or a TLS connection, use port 25, 2525, or 587."
      "relayServer": {
        "type": "string",
        "description": "This setting is sometimes referred to as the external SMTP server or the SMTP relay."
    "additionalProperties": false,
    "required": [
      "relayServer",
      "port",
      "isEnabled"
  "state": "valid",
  "stateUnready": [],
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 503, Service unavailable
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/41",
  "title": "Service not ready",
  "detail": "Currently, the service can't respond to this request.",
  "status": "503"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_json
type_json
properties
type_json_schema
$schema
string
True
type
string
True
properties
properties
True
boolean
True
required
array[string]
True
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
