Retrieve an upgrade
Retrieves an upgrade resource, providing the stored upgrade configuration for review or management purposes.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/upgrades/{upgrade_id}
Usage notes
Returns the stored Upgrade API resource in the JSON response body.
account_id |
string |
path |
True |
upgrade_id |
string |
path |
True |
ID of the upgrade collection to list |
Status: 200, Returns the stored Upgrade API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
componentName |
string |
True |
JSON string containing the name of the type of software that can be upgraded. Defined values are:
componentInstance |
string |
True |
JSON string containing the URI of the component that can be upgraded. Defined values are:
componentID |
string |
True |
JSON string containing a globally unique identifier of the component that can be upgraded. Defined values are:
upgradeVersion |
string |
True |
JSON string containing the SemVer of the software image file that can be upgraded to. Defined values are:
currentVersion |
string |
True |
JSON string containing the current SemVer of the entity to be upgraded. Defined values are:
dependencies |
array[string] |
True |
JSON array of JSON strings, each containing the UUID of an upgrade that must be completed before this upgrade can proceed. Used to determine which upgrades will be performed as prerequisites and in which order. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the upgrade. If auto-upgrade is enabled, upgrades will start in the "scheduled" state. Otherwise, upgrades will start in the "proposed" state. Defined values are:
stateDesired |
string |
True |
JSON string containing a value indicating the desired state for "state". This field is only included when the user can directly request a change in the state of the resource. Defined values are:
stateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about the current "state". If no details are available, this array will be empty.
metadata |
True |
"type": "application/astra-upgrade",
"version": "1.1",
"id": "aa9a8e88-c012-55b1-b514-7cd94dc79008",
"componentName": "trident",
"componentInstance": "https://<dns_name>/accounts/0b311ae7-d89a-4a11-a52c-1349ca090415/topology/v1/clouds/fdda3ff3-a46a-43a4-902e-444fde2baeba/storageBackends/72d19c3c-eb43-4bec-b23e-a228c900aded",
"componentID": "72d19c3c-eb43-4bec-b23e-a228c900aded",
"upgradeVersion": "21.07.1",
"currentVersion": "21.04.1",
"dependencies": [],
"state": "scheduled",
"stateDesired": "scheduled",
"stateDetails": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
additionalDetails
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
