Retrieve an unread notification
GET /accounts/{account_id}/core/v1/users/{user_id}/unreadNotifications/{unreadNotification_id}
Returns the stored Unread Notification API resource in the JSON response body.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
user_id |
string |
path |
True |
ID of the containing user resource |
unreadNotification_id |
string |
path |
True |
ID of the unreadNotification collection to list |
Status: 200, Returns the stored Unread Notification API resource in the JSON response body.
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
notificationID |
string |
True |
JSON string containing a notification ID that is to be marked as read by the user creating the mark. Defined values are:
sequenceCount |
number |
True |
JSON number containing a sequence count associated with the notification specified by the notification ID. |
severity |
string |
True |
JSON string containing one of the following values that indicate the severity of the event. Defined values are:
metadata |
True |
"type": "application/astra-unreadNotification",
"version": "1.0",
"id": "10df997b-629e-50f8-bc5f-a18b9a4ac5f6",
"notificationID": "4080cf5f-2261-4130-b8fb-8432e2e553e6",
"sequenceCount": 48923,
"severity": "warning",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
