List all buckets
Retrieves a list of buckets, providing a JSON array of all matching resources in the collection. Use this to examine the available buckets and their specified fields.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/buckets
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: bucket_1.2_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-buckets",
"version": "1.2",
"items": [
"4c753e39-25e9-4b36-a8de-69f168aa59cd",
"Test Bucket",
"gcp"
"d8fd585d-6429-4c08-a308-af193a88eac7",
"Local",
"ontap-s3"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
additionalDetails
type_astra_stateDetail
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
s3
JSON object that provides Simple Storage Service (S3) protocol parameters. (Use this object for all S3 type providers).
serverURL |
string |
True |
JSON string containing a URL to the base path for the bucket. Defined values are:
bucketName |
string |
True |
JSON string containing the name of the S3 bucket. Defined values are:
gcp
JSON object that provides Google Cloud protocol parameters.
bucketName |
string |
True |
JSON string containing the name of the backing Google Cloud bucket name. Defined values are:
azure
JSON object that provides Azure protocol parameters.
storageAccount |
string |
True |
JSON string containing the Azure storage account name. Defined values are:
bucketName |
string |
True |
JSON string containing the name of the backing Azure blob name. Defined values are:
bucketParameters
JSON object that provides bucket provider-specific information required to access the bucket. The specific values in this bucket vary per provider.
s3 |
False |
JSON object that provides Simple Storage Service (S3) protocol parameters. (Use this object for all S3 type providers). |
gcp |
False |
JSON object that provides Google Cloud protocol parameters. |
azure |
False |
JSON object that provides Azure protocol parameters. |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-assigned name for the bucket. Defined values are:
credentialID |
string |
True |
JSON string containing the identifier of the credentials used to access the bucket. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the bucket. Defined values are:
stateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about why "state" transitioned to "removed" or "failed". If no details are available, this array will be empty.
provider |
string |
True |
JSON string indicating the bucket protocol that can be used to access the bucket. Defined values are:
bucketParameters |
True |
JSON object that provides bucket provider-specific information required to access the bucket. The specific values in this bucket vary per provider. |
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
