Astra Automation
List the namespaces for a cluster
Retrieves the namespaces for a cluster, providing a list of all matching resources in the collection. Use this to view specific fields for each resource as needed.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/clusters/{cluster_id}/namespaces
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
cluster_id
string
path
True
ID of the containing cluster resource
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,name,kubernetesLabels
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: namespace_1.1_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-namespaces",
  "version": "1.1",
  "items": [
      "7d451d2f-196e-4234-aee9-7e2376047e63",
      "kube-system",
          "name": "app.kubernetes.io/environment",
          "value": "dev"
      "66b0873b-214f-4ac7-89d8-922432f941eb",
      "jenkins",
          "value": "dev"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
targetSchema
accept-post
accept-put
hints
status
string
False
allow
array[string]
False
accept-post
accept-post
False
permissions
array[string]
False
accept-put
accept-put
False
rel
string
True
string
True
type
string
False
targetSchema
targetSchema
False
title
string
False
hints
hints
False
additionalDetails
type_astra_stateDetail
type
string
True
title
string
True
detail
string
True
additionalDetails
additionalDetails
False
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-namespace"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
links
array[type_astra_link]
True
Links describing supported operations against the resource.
name
string
True
JSON string containing a value indicating the name of the namespace. Defined values are:
  • Minimum length: 1
  • Maximum length: 255
namespaceState
string
True
JSON string containing a value indicating the state of the namespace. Defined values are:
  • "discovered" - The namespace has been found in the cluster
  • "removed" - The namespace has been deleted from the cluster, or the cluster is not managed but there might be resources referring to the namespace
namespaceStateDetails
array[type_astra_stateDetail]
True
JSON array of JSON objects that lists additional details about why "state" transitioned into "state a", "state b", or "state c". If no details are available, this array will be empty. Defined values are:
  • Minimum items: 0
kubernetesLabels
False
JSON array of JSON objects, each containing a Kubernetes label associated with the namespace. Defined values are:
  • Conforms to the Kubernetes Label Array Schema
clusterID
string
True
JSON string containing a globally unique identifier of the cluster that the namespace is contained in. Defined values are:
  • Conforms to the Astra Identifier Schema
systemType
string
False
JSON string that denotes that the namespace is a type of system namespace. This field identifies what type of system namespace, if any, the namespace is (version 1.1 only). Defined values are:
  • "kubernetes" - A generic Kubernetes (K8s) system namespace, for example, "kube-system"
  • "netapp" - A NetApp system namespace, for example, "trident" or "netapp-monitoring"
  • "openshift" - An OpenShift system namespace, for example, "openshift-monitoring"
  • "rke" - A Rancher namespace, for example, "cattle-logging"
  • "other" - Common system namespaces that don't necessarily fit elsewhere, for example, "ingress-nginx", "tekton-system"
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
