Retrieve a volume for a managed cluster
Retrieves a volume for a managed cluster, providing access to the stored volume information for further management or analysis.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/managedClusters/{managedCluster_id}/volumes/{volume_id}
Usage notes
Returns the stored Volume API resource in the JSON response body.
account_id |
string |
path |
True |
managedCluster_id |
string |
path |
True |
ID of the containing managedCluster resource |
volume_id |
string |
path |
True |
ID of the volume collection to list |
Status: 200, Returns the stored Volume API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing the name of the volume. Defined values are:
state |
string |
False |
JSON string containing a value indicating the operational state of the volume. |
size |
string |
False |
JSON string containing the size of the volume. |
used |
number |
False |
JSON number containing the number of bytes of quota used by the provisioned volume. |
usedPercentage |
number |
False |
JSON number containing the percentage of volume used. |
total |
number |
False |
JSON number containing the total bytes of volumes provisioned. |
creationToken |
string |
False |
JSON string containing the creation token of the volume. Defined values are:
snapshotPossible |
string |
False |
JSON string indicating whether the driver can perform a snapshot of the volume. Defined values are:
storageClass |
string |
False |
JSON string containing the storage class for the volume.
pvcName |
string |
False |
JSON string containing the PersistentVolumeClaim (PVC) name of the volume.
internalName |
string |
False |
JSON string containing the internal name of the volume on the target storage cluster, if available. This name is obtained from the Kubernetes CSI driver.
appsUsing |
array[string] |
True |
JSON array of JSON strings, each containing the ID of an application that is using the volume. Defined values are:
storageBackendID |
string |
False |
JSON string containing the ID of the storage backend that provides the volume. Defined values are:
orchestrator |
string |
False |
JSON string containing the orchestrator for this volume. This will be defined for Astra Data Store volumes. Defined values are:
serviceLevel |
string |
False |
JSON string containing the quality of service (QoS) policy defined for this volume at the storage backend level. This will be defined for Astra Data Store volumes. |
exportPolicy |
string |
False |
JSON string containing the export policy associated with this volume. This will be defined for Astra Data Store volumes. |
nodeId |
string |
False |
JSON string containing the node ID serving the volume. This will be defined for Astra Data Store volumes. Defined values are:
healthState |
string |
False |
JSON string containing a value indicating the health state of the volume. This will be defined for Astra Data Store volumes. Defined values are:
healthStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about the current health. If no details are available, this array will be empty.
metadata |
True |
"type": "application/astra-volume",
"version": "1.2",
"id": "ab5c9fb8-ddba-526f-8bd3-8d5b72cf4f7f",
"name": "myVolume",
"state": "ready",
"size": "512 GiB",
"used": 10000000000,
"usedPercentage": 10,
"total": 10000000000,
"creationToken": "ba7d4e0c-6ae3-4b6e-859d-9463e7ca4b4e",
"snapshotPossible": "true",
"storageClass": "gold",
"pvcName": "myVolume",
"internalName": "trident_sd234234_23424_897d_876sd65w",
"appsUsing": [],
"orchestrator": "trident",
"serviceLevel": "gold",
"exportPolicy": "astra-vp-default",
"nodeId": "94d16dd2-9beb-4edb-ab58-1a00e9a90052",
"healthState": "normal",
"healthStateDetails": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
additionalDetails
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
