Astra Automation
Create a new package
Creates a package in the Astra API, specifying desired values for the Package API resource. Use this to define the package's attributes and configurations.
HTTP method and endpoint
POST /accounts/{account_id}/core/v1/packages
Usage notes
Indicates desired values for the Package API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
Request Body
type
string
True
  • "application/astra-package"
version
string
True
  • "1.0"
packageName
string
True
JSON string containing the package name. Defined values are:
  • Minimum length: 1
  • Maximum length: 31 Example values are:
  • "acc"
  • "acs"
  • "trident"
packageVersion
string
True
JSON string containing the SemVer of the package. Defined values are:
  • Conforms to the SemVer Schema
packageType
string
True
JSON string containing the package type, indicating whether this is a full installation package or a patch. Defined values are:
  • "install"
  • "patch"
bundleName
array[string]
False
JSON array of JSON strings containing the name of the bundle that the package is contained in.
severityLevel
string
True
JSON string describing the severity level of this patch or installation. Defined values are:
  • "recommended" - Installation is recommended - Default value
  • "critical" - Installation is strongly recommended to address critical bug fixes and/or security patches
images
array[images]
False
JSON array of JSON objects, each containing a Docker image that is part of the package.
artifacts
array[artifacts]
False
JSON array of JSON objects describing the additional artifacts (binaries and others) associated with this package.
files
array[files]
False
JSON array of JSON objects, each representing a non-image artifact associated with this package.
upgradableVersions
upgradableVersions
False
JSON object containing the minimum and maximum versions that can be upgraded to the package version.
dependencies
array[dependencies]
False
JSON array of JSON objects describing what minimum version of a given dependency is required for this package to be installed
metadata
type_astra_metadata
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
Example request
  "type": "application/astra-package",
  "version": "1.0",
  "packageName": "acc",
  "packageVersion": "22.09.1",
  "packageType": "patch",
  "severityLevel": "recommended",
  "images": [
      "imagePath": "/globalcicd/acc",
      "imageName": "storage-provider",
      "imageTag": "1.3.116",
      "imageDigest": "sha256:2e04d178815537b0ad8c3224e8754e3364456781a161f1be239853dae33deafc"
      "imageName": "storage-backend-metrics",
      "imageTag": "1.3.45",
      "imageName": "credentials",
      "imageDigest": "sha256:2e04d178815537b0ad8c322445654e33642da781a161f1be239853dae33deafc"
  "files": [
      "fileName": "astra_control_center_min.yaml",
      "fileIdentifier": "astra_min",
      "fileMediaType": "application/x-yaml",
      "fileContents": "VGhpcyBpcyBzdXBwb3NlZCB0byBiZSBhIGNvbXByZXNzZWQgZmlsZSBjb250ZW50"
  "dependencies": [
      "componentName": "acc",
      "componentMinVersion": "22.04.29"
      "componentName": "kubernetes",
      "componentMinVersion": "v1.19.7",
      "componentMaxVersion": "v1.22"
      "componentName": "trident",
      "componentMinVersion": "v21.01.1"
Status: 201, Returns the newly created package resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
id
string
True
packageName
string
True
  • Minimum length: 1
  • "acc"
  • "acs"
  • "trident"
packageVersion
string
True
packageType
string
True
  • "install"
  • "patch"
bundleName
array[string]
False
severityLevel
string
True
packageState
string
True
JSON string containing a value indicating the operational state of the package. After verification of the package and after import, the state will indicate "complete". Otherwise, the state will indicate "incomplete". Defined values are:
  • "verifying" - The package is in the process of being validated
  • "corrupt" - The package is corrupt
  • "incomplete" - The package is missing elements
  • "available" - All elements associated with the package are available and the package is ready for use
packageStateTransitions
array[type_astra_stateTransition]
True
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state and the "to" value is an array of permitted destination states. Defined values are:
  • Conforms to the State Transition Schema
packageStateDetails
array[type_astra_stateDetail]
True
JSON array of JSON objects that lists additional details about the current "state". If no details are available, this array will be empty.
  • Minimum Items: 0
images
array[images]
False
artifacts
array[artifacts]
False
files
array[files]
False
upgradableVersions
upgradableVersions
False
dependencies
array[dependencies]
False
metadata
type_astra_metadata
True
  "version": "1.0",
  "id": "54edc2b3-18c5-5371-904b-ebcd04d88bdc",
  "packageState": "available",
  "packageStateTransitions": [
      "from": "verifying",
      "to": [
        "corrupt",
        "incomplete",
        "available"
      "from": "corrupt",
      "to": [
        "incomplete",
        "available"
      "from": "incomplete",
      "to": [
        "corrupt",
        "available"
      "from": "available",
      "to": [
        "corrupt",
        "available"
  "packageStateDetails": [],
  "images": [
      "imageDigest": "sha256:2e04d178815537b0ad8c3224e8754e33642da781a161f1be239853dae33deafc"
  "files": [
  "dependencies": [
      "componentMaxVersion": "v1.20"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
dependsOnImages
imagePath
string
True
JSON string containing the path to this Docker image. It must not contain the name of the registry, only the absolute path from root to image. Example: /globalcicd/acc Defined values are:
  • Minimum length: 1
  • Maximum length: 1023
imageName
string
True
JSON string containing the Docker image name. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
imageTag
string
True
JSON string representing the tag/version of this image. Defined values are:
  • Minimum length: 1
images
imageName
string
True
  • Minimum length: 1
imagePath
string
True
  • Minimum length: 1
imageTag
string
True
  • Minimum length: 1
imageDigest
string
True
JSON string representing the digest of this image. Defined values are:
  • Defined regex is: "^(sha256:)[0-9a-f]{64}$"
dependsOnImages
array[dependsOnImages]
False
JSON array of JSON objects describing the images required to install or upgrade the current image.
dependsOnComponents
componentName
string
True
JSON string describing the name of the component. Defined values are:
  • "acc"
  • "acs"
  • "trident"
  • "kubernetes"
versions
array[string]
True
JSON array of JSON strings defining the component version required to install the current image.
artifacts
artifactName
string
True
JSON string containing the file name. Defined values are:
  • Minimum length: 1
artifactIdentifier
string
True
JSON string containing an identifier for this file. Between versions of the same package type, the file name might change but the identifier usually stays the same. Defined values are:
  • Minimum length: 1
  • Maximum length: 511
artifactPath
string
True
JSON string containing the path to this artifact from the root of a known Astra Control Center Data Store/location. Example: /vmware/1.0/ Defined values are:
  • Minimum length: 1
artifactVersion
string
False
JSON string containing the version of that artifact, if provided. Defined values are:
  • Minimum length: 1
dependsOnComponents
array[dependsOnComponents]
False
JSON array of JSON objects describing the installed components required to install/upgrade the current image.
files
fileName
string
True
  • Minimum length: 1
fileIdentifier
string
True
JSON string containing an identifier of this file. Between versions of the same package type, the file name might change but the identifier usually stays the same. Defined values are:
  • Minimum length: 1
fileMediaType
string
True
JSON string containing the file media-type. Defined values are any media type defined by IANA. In addition, application/x-yaml or application/x-yaml for yaml files is supported.
  • Minimum length: 1
  • Maximum length: 211
fileContents
string
True
JSON string containing the file content. Defined values are:
  • Conforms to the Base64 Schema FIXME - How do we specify that this is compressed? What algorithm ,etc?
upgradableVersions
minVersion
string
False
JSON string describing the minimum version that can be upgraded to the package version. Defined values are:
maxVersion
string
False
JSON string describing the maximum version that can be upgraded to the package version. Defined values are:
dependencies
componentName
string
True
  • "acc"
  • "acs"
  • "trident"
  • "kubernetes"
componentMinVersion
string
False
JSON string describing the minimum version required of that component. Defined values are:
componentMaxVersion
string
False
JSON string describing the maximum version required of that component. Defined values are:
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
from
string
True
to
array[string]
True
additionalDetails
type
string
True
title
string
True
detail
string
True
additionalDetails
additionalDetails
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
