Astra Automation
Modify a token for a user in a group
PUT /accounts/{account_id}/core/v1/groups/{group_id}/users/{user_id}/tokens/{token_id}
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
account_id
string
path
True
  • example: {{.Account}}
group_id
string
path
True
ID of the containing group resource
user_id
string
path
True
ID of the containing user resource
token_id
string
path
True
ID of the token collection to list
Request Body
type
string
True
  • "application/astra-token"
version
string
True
  • "1.0"
id
string
False
name
string
False
JSON string containing a token name. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks.
userID
string
False
JSON string containing the UUID for the user that the token is associated with. Defined values are:
  • Conforms to the Astra Identifier Schema
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-token",
  "version": "1.0",
  "name": "New Token Name"
JSON
Status: 204, Indicates if the token resource was updated.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
JSON
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
JSON
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
modificationTimestamp
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
