Modify an upgrade
Modifies an upgrade by replacing the entire stored resource with the supplied JSON request body. Use this endpoint to schedule or run upgrades based on the desired state.
HTTP method and endpoint
PUT /accounts/{account_id}/core/v1/upgrades/{upgrade_id}
Usage notes
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
Upgrades are scheduled or run based on desired state.
account_id |
string |
path |
True |
upgrade_id |
string |
path |
True |
ID of the upgrade collection to list |
Request Body
Side Effects
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
componentName |
string |
False |
JSON string containing the name of the type of software that can be upgraded. Defined values are:
componentInstance |
string |
False |
JSON string containing the URI of the component that can be upgraded. Defined values are:
componentID |
string |
False |
JSON string containing a globally unique identifier of the component that can be upgraded. Defined values are:
upgradeVersion |
string |
False |
JSON string containing the SemVer of the software image file that can be upgraded to. Defined values are:
currentVersion |
string |
False |
JSON string containing the current SemVer of the entity to be upgraded. Defined values are:
dependencies |
array[string] |
False |
JSON array of JSON strings, each containing the UUID of an upgrade that must be completed before this upgrade can proceed. Used to determine which upgrades will be performed as prerequisites and in which order. Defined values are:
state |
string |
False |
JSON string containing a value indicating the operational state of the upgrade. If auto-upgrade is enabled, upgrades will start in the "scheduled" state. Otherwise, upgrades will start in the "proposed" state. Defined values are:
stateDesired |
string |
False |
JSON string containing a value indicating the desired state for "state". This field is only included when the user can directly request a change in the state of the resource. Defined values are:
stateDetails |
array[type_astra_stateDetail] |
False |
JSON array of JSON objects that lists additional details about the current "state". If no details are available, this array will be empty.
metadata |
False |
Example request
"type": "application/astra-upgrade",
"version": "1.1",
"stateDesired": "running"
Status: 204, Indicates if the upgrade resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
additionalDetails
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
