Astra API (ACC) execution hook override endpoints
Disable the preloaded NetApp execution hooks for a specific application. Check the deprecation information on the page before you use these endpoints.
The Execution Hook Override API allows a user to disable the preloaded "netapp" execution hooks for a specific application. (NOTE BELOW API DEPRECATIONS)
