Uninstall Astra Control Center
You might need to remove Astra Control Center components if you are upgrading from a trial to a full version of the product. To remove Astra Control Center and the Astra Control Center Operator, run the commands described in this procedure in sequence.
What you’ll need
Use Astra Control Center UI to unmanage all clusters.
Steps
Delete Astra Control Center. The following sample command is based upon a default installation. Modify the command if you made custom configurations.
kubectl delete -f astra_control_center_min.yaml -n netapp-acc
Result:
astracontrolcenter.astra.netapp.io "astra" deleted
Use the following command to delete the
netapp-acc
namespace:kubectl delete ns netapp-acc
Result:
namespace "netapp-acc" deleted
Use the following command to delete Astra Control Center operator system components:
kubectl delete -f astra_control_center_operator_deploy.yaml
Result:
namespace "netapp-acc-operator" deleted customresourcedefinition.apiextensions.k8s.io "astracontrolcenters.astra.netapp.io" deleted role.rbac.authorization.k8s.io "acc-operator-leader-election-role" deleted clusterrole.rbac.authorization.k8s.io "acc-operator-manager-role" deleted clusterrole.rbac.authorization.k8s.io "acc-operator-metrics-reader" deleted clusterrole.rbac.authorization.k8s.io "acc-operator-proxy-role" deleted rolebinding.rbac.authorization.k8s.io "acc-operator-leader-election-rolebinding" deleted clusterrolebinding.rbac.authorization.k8s.io "acc-operator-manager-rolebinding" deleted clusterrolebinding.rbac.authorization.k8s.io "acc-operator-proxy-rolebinding" deleted configmap "acc-operator-manager-config" deleted service "acc-operator-controller-manager-metrics-service" deleted deployment.apps "acc-operator-controller-manager" deleted
