Astra Control Center
Add and remove credentials
Contributors netapp-mwallis
Add and remove credentials for local private cloud providers such as ONTAP S3, Kubernetes clusters managed with OpenShift, or unmanaged Kubernetes clusters from your account at any time. Astra Control Center uses these credentials to discover Kubernetes clusters and the apps on the clusters, and to provision resources on your behalf.
Note that all users in Astra Control Center share the same sets of credentials.
Add credentials
You can add credentials to Astra Control Center when you manage clusters. To add credentials by adding a new cluster, refer to Add a Kubernetes cluster.
Note If you create your own kubeconfig file, you should define only one context element in it. Refer to Kubernetes documentation for information about creating kubeconfig files.
Remove credentials
Remove credentials from an account at any time. You should only remove credentials after unmanaging all associated clusters.
Note The first set of credentials that you add to Astra Control Center is always in use because Astra Control Center uses the credentials to authenticate to the backup bucket. It's best not to remove these credentials.
Steps
  1. Select Account.
  2. Select the Credentials tab.
  3. Select the Options menu in the State column for the credentials that you want to remove.
  4. Select Remove.
  5. Type the word "remove" to confirm deletion and then select Yes, Remove Credential.
Result
Astra Control Center removes the credentials from the account.
