BlueXP alerts
Set up BlueXP alerts
Contributors amgrissino
To use BlueXP alerts, perform a few steps to set it up.
Before you begin, review prerequisites to ensure that your environment is ready.
Access to cluster resources
To view the alerts, the logged in user must be part of the BlueXP organization and should have the required access to the cluster resource.
Create a BlueXP Connector
You should reach out to your NetApp Sales Rep to try out or use this service. Then, when you use the BlueXP Connector, it will include the appropriate capabilities for the alerts service.
To create a Connector in BlueXP before using the service, refer to the BlueXP documentation that describes how to create a BlueXP Connector.
After you set up the Connector and add the working environment, wait about 15 minutes for the initial discovery.
