Learn about ONTAP alerts in NetApp Console
Contributors amgrissino netapp-ahibbard
View issues or potential risks in your NetApp on-premises ONTAP systems using the NetApp Console. You can drill into details using ONTAP System Manager.
NetApp Console
View ONTAP alerts in the NetApp Console.
The NetApp Console provides centralized management of NetApp storage and data services across on-premises and cloud environments at enterprise grade. The Console is required to access and use NetApp data services. As a management interface, it enables you to manage many storage resources from one interface. Console administrators can control access to storage and services for all systems within the enterprise.
You don't need a license or subscription to start using the NetApp Console and you only incur charges when you need to deploy Console agents in your cloud to ensure connectivity to your storage systems or NetApp data services. However, some NetApp data services accessible from the Console are licensed or subscription-based.
Learn more about the NetApp Console.
What you can do with ONTAP alerts
View ONTAP alerts to stay informed about risks or potential risk in your ONTAP storage system. You can see some non-EMS alerts and some EMS alerts. You can see information about these severities and impact areas:
  • Severities: Critical, Warning, Informational
  • Impact areas: Capacity, Performance, Protection, Availability, Security, Configuration
Tip The Notifications option in the upper right of the NetApp Console UI monitors the status of operations that NetApp Console is performing to help you identify issues that you need to address. You can have these notifications sent to your email. The Notifications option does not include the alerts from ONTAP alerts.
Benefits of monitoring ONTAP alerts
Monitoring ONTAP alerts provides the following benefits:
  • Get alerts about your ONTAP storage across clusters.
  • View alerts in the same NetApp Console UI that you use for other services.
  • Drill into alerts on ONTAP clusters — start from the NetApp Console and see details in ONTAP System Manager.
Cost
You can view ONTAP alerts with a NetApp ONTAP license.
Licensing
Viewing ONTAP alerts requires a NetApp ONTAP 9.10 or greater license.
You do not need to have a trial license.
ONTAP alerts can be viewed in the NetApp Console standard (public) mode only.
How ONTAP alerts work
ONTAP alerts is a core component of NetApp Console. ONTAP alerts monitors ONTAP clusters and receives alert data from ONTAP.
ONTAP alerts is available only in the NetApp Console SaaS environment. It is not available in a local Console agent UI.
Supported systems and data sources
Use ONTAP alerts to check on issues in the following systems and data sources.
Systems supported
An on-premises ONTAP NAS or SAN system is supported.
Cloud Volumes ONTAP systems are not supported at this time.
Data sources supported
View alerts regarding certain events that occur in ONTAP. They are a combination of EMS and metric-based alerts.
