Retrieve account records
GET /audit/{accountId}
Retrieves account records by a specified account public ID.
Token usage: BlueXP user token.
accountId
string
path
True
fromLastModified
number
query
False
toLastModified
number
query
False
fromStartTime
number
query
False
qAction
string
query
False
qService
string
query
False
qStatus
string
query
False
qAgent
string
query
False
qResource
string
query
False
qUser
string
query
False
toStartTime
number
query
False
offset
number
query
False
Status: 200,
GetAuditGroupResDto
accountId
string
True
startTime
number
True
The start time of the event. Unix epoch in milliseconds
endTime
number
True
action
string
True
Action name of the event.
status
string
True
Status of the operation.
requestId
string
True
RequestId of the operation. globally unique for the service.
service
string
True
Service in which the operation was performed.
principalId
string
True
Id of the entity performing the operation.
agentName
string
False
Name of the agent which performed the operation.
agentId
string
False
Id of the agent which performed the operation.
resourceName
string
False
Name of the resource acted upon by the operation.
resourceId
string
False
Id of the resource acted upon by the operation.
errors
array[string]
False
Array of error message/s if exists. that related to this auditGroup
requestData
string
False
Parameters related to request of operation. a string, can be JSON string
responseData
string
False
Response of the operation. Must be a string, can be JSON in a string.
workspaceId
string
False
Id of the workspace in which the resource is contained.
hasRecords
boolean
True
hasFailedRecord
boolean
True
lastModified
number
True
Last modified time. Unix epoch in milliseconds
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
