BlueXP backup and recovery for VMs
Known limitations
Contributors netapp-revathid
Known limitations identify functions that are not supported by this release of the product, or that do not interoperate correctly with it. Review these limitations carefully.
  • BlueXP backup and recovery for VMs does not support Amazon FSx for ONTAP’s automatic daily backups.
  • The maximum limit of datastores that can be mounted are four.
  • BlueXP backup and recovery for VMs shows secondary location twice if snapshot locking is enabled. This issue is fixed in ONTAP 9.14.1RC1, ONTAP 9.13.1P4 - ONTAP 9.13.1P5, and ONTAP 9.12.1P8 - ONTAP 9.12.1P9.
