Deploy BlueXP backup and recovery for VMs
To protect VMs and datastores on virtualized machines, you must deploy BlueXP backup and recovery for VMs.
The OVA deployment is supported in VMware vCenter 8.0 and above. |
You must have read the deployment requirements.
You must be running a supported version of VMC on AWS.
You must have configured and set up your VMC on AWS environment.
You must have set up an ESXi host for BlueXP backup and recovery for VMs.
You must have downloaded BlueXP backup and recovery for VMs
.tarfile. -
You must have the login authentication details for your VMC on AWS instance.
You must have a certificate with valid Public and Private Key files. For more information, see articles under Storage Certificate Management section.
You must have logged out of and closed all browser sessions of vSphere client and deleted the browser cache to avoid any browser cache issue during the deployment of BlueXP backup and recovery for VMs.
You must have enabled Transport Layer Security (TLS) in vCenter. Refer to the VMware documentation.
You must have deployed BlueXP backup and recovery for VMs in the same time zone as the vCenter.
For VMware vCenter 7.0.3 and later versions, follow the steps in Download the Open Virtual Appliance (OVA) section to import the certificates to vCenter.
In your browser, navigate to VMware vSphere vCenter.
Log in to the VMware vCenter Single Sign-On page.
On the Navigator pane, right-click any inventory object that is a valid parent object of a virtual machine, such as a datacenter, cluster, or host, and select Deploy OVF Template to start the VMware deploy wizard.
Extract the
.tarfile, which contains the.ovafile onto your local system. On the Select an OVF template page, specify the location of the.ovafile inside the.tarextracted folder. -
Click Next.
On the Select a name and folder page, enter a unique name for the VM or vApp, and select a deployment location, and then click Next.
This step specifies where to import the
.ovafile into vCenter. The default name for the VM is the same as the name of the selected.ovafile. If you change the default name, choose a name that is unique within each VMC on AWS VM folder.The default deployment location for the VM is the inventory object where you started the wizard.
On the Select a resource page, select the resource where you want to run the deployed VM template, and click Next.
On the Review details page, verify the
.ovatemplate details and click Next. -
On the License agreements page, select the checkbox for I accept all license agreements.
On the Select storage page, define where and how to store the files for the deployed OVF template.
Select the disk format for the VMDKs.
Select a VM Storage Policy.
This option is available only if storage policies are enabled on the destination resource.
Select a datastore to store the deployed OVA template.
The configuration file and virtual disk files are stored on the datastore.
Select a datastore large enough to accommodate the virtual machine or vApp and all associated virtual disk files.
On the Select networks page, do the following:
Select a source network and map it to a destination network.
The Source Network column lists all networks that are defined in the OVA template.
In the IP Allocation Settings section, select the required IP protocol and then click Next.
BlueXP backup and recovery for VMs supports one network interface. If you need multiple network adapters, you must set that up manually.
On the Customize template page, do the following:
In the Register to existing vCenter section, enter the vCenter name and the vCenter credentials of the virtual appliance.
In the vCenter username field, enter the username in the format domain\username.
In the Create BlueXP backup and recovery for VMs credentials section, enter the local credentials.
In the Username field, enter the local username; do not include the domain details.
Make a note of the username and password that you specify. You need to use these credentials if you want to modify BlueXP backup and recovery for VMs configuration later.
Enter credentials for the maint user.
In Setup Network Properties, enter the host name.
In Setup IPv4 Network Properties section, enter the network information such as IPv4 address, IPv4 Netmask, IPv4 Gateway, IPv4 Primary DNS, IPv4 Secondary DNS, and IPv4 Search Domains.
You can skip these steps and leave the entries blank in the Setup Network Properties section, if you want to proceed with DHCP as your network configuration.
In Setup Date and Time, select the time zone where the vCenter is located.
On the Ready to complete page, review the page and click Finish.
All hosts must be configured with IP addresses (FQDN hostnames are not supported). The deploy operation does not validate your input before deploying.
You can view the progress of the deployment from the Recent Tasks window while you wait for the OVF import and deployment tasks to finish.
When BlueXP backup and recovery for VMs is successfully deployed, it is deployed as a Linux VM, registered with vCenter, and a VMware vSphere client is installed.
Navigate to the VM where BlueXP backup and recovery for VMs was deployed, then click the Summary tab, and then click the Power On box to start the virtual appliance.
While BlueXP backup and recovery for VMs is powering on, right-click the deployed BlueXP backup and recovery for VMs, select Guest OS, and then click Install VMware tools.
