BlueXP backup and recovery
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Restore Kubernetes applications
Contributors netapp-mwallis
BlueXP backup and recovery enables you to restore applications that you have protected with a protection policy. To restore an application, an application needs to have at least one restore point available. A restore point consists of either the local snapshot or the backup to the object store (or both). You can restore an application using the local, secondary, or object store archive.
Required BlueXP role
Organization admin or SnapCenter admin. Learn about BlueXP backup and recovery access roles. Learn about BlueXP access roles for all services.
Steps
  1. In BlueXP backup and recovery, select Inventory.
  2. Choose a Kubernetes instance, and select View to view the resources associated with that instance.
  3. Select the Applications tab.
  4. In the list of applications, choose an application you want to restore and select the associated Actions menu.
  5. Select View and restore.
    The list of restore points appears.
  6. Open the Actions menu for the restore point you want to use, and select Restore.
General settings
  1. Choose the source to restore from (local or object store).
  2. Choose the destination cluster from the Cluster list.
  3. Choose the restore destination namespace.
    You can restore to the original namespace or restore to a new namespace.
  4. Select Next.
Resource selection
  1. Choose whether you want to restore all resources associated with the application or use a filter to select specific resources to restore:
Restore all resources
  1. Select Restore all resources.
  2. Select Next.
Restore specific resources
  1. Select Selective resources.
  2. Choose the behavior of the resource filter. If you choose Include, the resources you select are restored. If you choose Exclude, the resources you select are not restored.
  3. Select Add rules to add rules that define filters for selecting resources. You need at least one rule to filter resources.
    Each rule can filter on criteria such as the resource namespace, labels, group, version, and kind.
  4. Select Save to save each rule.
  5. When you have added all the rules you need, select Search to see the resources available in the backup archive that match your filter criteria.
    Note The resources shown are the resources that currently exist on the cluster.
  6. When satisfied with the results, select Next.
Destination settings
  1. Choose to restore either to the default storage class or to a different storage class.
  2. Optionally, if you chose to restore to a different storage class, select a destination storage class to match each source storage class.
  3. Select Restore.
