Configure advanced settings in BlueXP backup and recovery
Some advanced settings might be helpful in maintaining your backup and recovery environment. You can configure advanced settings to manage your inventory, delete backups, unregister resources, delete relationships, unprotect resources to stop service charges, set the max transfer rate for the SnapMirror relationship, export snapshot copies to an object store, enable automatic yearly snapshot deletion, enable maintenance mode, and update the Application Plugin.
Configure BlueXP backup and recovery advanced settings in the following ways:
Delete backups.
Unregister backups, databases, instances, or application hosts.
Delete the relationships.
Unprotect databases, instances, application hosts, and work environments to stop service charges.
Set the max transfer rate for the SnapMirror relationship - manage the bandwidth usage, ensuring that SnapMirror operations don't interfere with other network activities.
Export snapshot copies to an object store to initialize backups in the cloud by moving older snapshot copies into the baseline backup copy.
Enable automatic yearly snapshot deletion
Enable maintenance mode so that updates or maintenance tasks can be performed.
Update the Application Plugin.
Delete backups
You can delete backups to free up space in your storage.
In the BlueXP backup and recovery console, select Settings.
Select Advanced settings.
Select Delete backups.
Select the backup that you want to delete.
Select Delete.
You can unregister backups, databases, instances, or application hosts to remove them from the inventory.
Select Unregister resources.
Select the resource that you want to unregister.
Select Unregister.
Delete relationships
You can delete relationships to remove them from the inventory.
Select Delete relationships.
Select the relationship that you want to delete.
Select Delete.
You can unprotect databases, instances, application hosts, and work environments to stop service charges.
Select Unprotect resources.
You can set the max transfer rate for the SnapMirror relationship to manage the bandwidth usage, ensuring that SnapMirror operations don't interfere with other network activities.
Select Set the max transfer rate for the SnapMirror relationship.
Enter the max transfer rate.
Select Save.
You can export snapshot copies to an object store to initialize backups in the cloud by moving older snapshot copies into the baseline backup copy.
Select Export snapshot copies to an object store.
Select the snapshot copy that you want to export.
Select Export.
You can enable automatic yearly snapshot deletion to delete snapshots that are older than a year.
Select Enable automatic yearly snapshot deletion.
Select Enable.
You can enable maintenance mode so that updates or maintenance tasks can be performed.
Select Enable maintenance mode.
Select Enable.
You can update the Application Plugin to ensure that the latest features are available.
Select Update the Application Plugin.
Select Update.
