NetApp Backup and Recovery
Back up datastores to Google Cloud Platform with NetApp Backup and Recovery
Contributors netapp-mwallis
You can back up one or more datastores to Google Cloud Platform by integrating the SnapCenter Plug-in for VMware vSphere host with NetApp Backup and Recovery. This will help the VM administrators to easily and quickly back up and archive data for storage efficiency and accelerate cloud transition.
Note To switch to and from NetApp Backup and Recovery workloads, refer to Switch to different NetApp Backup and Recovery workloads.
Before you begin
Ensure that you have met all the virtual machine protection requirements before backing up datastores to the cloud.
Steps
  1. In the NetApp Console UI, select Protection > Backup and Recovery > Virtual Machines.
  2. Select action corresponding to the datastore that you want to back up and select Activate Backup.
  3. In the Assign Policy page, select the policy and select Next.
  4. Add the system.
    Configure the cluster management LIF that you want the Console to discover. After adding the system for one of the datastores, it can be reused for all the other datastores residing on the same ONTAP cluster.
    1. Select Add system corresponding to the SVM.
    2. In the Add system wizard:
      1. Specify the IP address of the cluster management LIF.
      2. Specify the credentials of the ONTAP cluster user.
    3. Select Add system.
  5. Select Google Cloud Platform to configure it as the cloud provider.
    1. Select the Google Cloud Project where you want the Google Cloud Storage bucket to be created for backups.
    2. In the Google Cloud Access Key field, specify the key.
    3. In the Google Cloud Secret Key field, specify the password.
    4. Select the region where you want to create the backups.
    5. Specify the IP space.
  6. Review the details and select Activate Backup.
