BlueXP backup and recovery
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Back up datastores to StorageGRID with BlueXP backup and recovery
Contributors amgrissino
You can back up one or more datastores to StorageGRID by integrating the SnapCenter Plug-in for VMware vSphere host with BlueXP backup and recovery. This will help the VM administrators to easily and quickly back up and archive data for storage efficiency and accelerate cloud transition.
NOTE To switch to and from BlueXP backup and recovery workloads, refer to Switch to different BlueXP backup and recovery workloads.
Before you begin
Ensure that you have met all the virtual machine protection requirements before backing up datastores to the cloud.
Steps
  1. In BlueXP UI, select Protection > Backup and recovery > Virtual Machines.
  2. Select action corresponding to the datastore that you want to back up and click Activate Backup.
  3. In the Assign Policy page, select the policy and select Next.
  4. Add the working environment.
    Configure the cluster management LIF that you want BlueXP to discover. After adding the working environment for one of the datastores, it can be reused for all the other datastores residing on the same ONTAP cluster.
    1. Select Add Working Environment corresponding to the SVM.
    2. In the Add Working Environment wizard:
      1. Specify the IP address of the cluster management LIF.
      2. Specify the credentials of the ONTAP cluster user.
    3. Select Add Working Environment.
  5. Select StorageGRID.
    1. Specify the Storage Server IP.
    2. Select the access key and secret key.
  6. Review the details and select Activate Backup.
