NetApp Backup and Recovery
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Create a policy to back up datastores in NetApp Backup and Recovery
Contributors netapp-mwallis
You can create a policy or use one of the following predefined policies that are available in NetApp Backup and Recovery.
Note To switch to and from NetApp Backup and Recovery workloads, refer to Switch to different NetApp Backup and Recovery workloads.
Before you begin
  • You should create policies if you do not want to edit the predefined policies.
  • To move backups from object store to archival storage, you should be running ONTAP 9.10.1 or later and Amazon Web Services or Microsoft Azure should be the cloud provider.
  • You should configure the archive access tier for each cloud provider.
About this task
The following predefined policies are available in the NetApp Console:
Policy Name Label Retention Value
1 Year Daily LTR (Long Term Retention)
Daily
366
5 Years Daily LTR
Daily
1830
7 Year Weekly LTR
Weekly
370
10 Year Monthly LTR
Monthly
120
Steps
  1. In the Virtual machines page, from the Settings drop-down list, select Policies.
  2. Select Create policy.
  3. In the Policy Details section, specify the policy name.
  4. In the Retention section, select one of the retention type and specify the number of backups to retain.
  5. Select Primary or Secondary as the backup storage source.
  6. (Optional) If you want to move backups from object store to archival storage after a certain number of days for cost optimization, select the Tier Backups to Archival checkbox and enter the number of days after which the backup should be archived.
  7. Select Create.
    Note You cannot edit or delete a policy, which is associated with a datastore.
