Create a custom classification in BlueXP classification
With BlueXP classification, you can create a custom search for sensitive information. The search can be scoped to a regular expression (regex).
Custom classification is only available for Map & Classify scans, not mapping-only scans. This feature is currently in preview.
Select the Custom classification tab.
Select the Add New Classifier button.
Add a Name and Description for the new classifier.
To add the customization as a regular expression, select Custom regular expression then Next.
Add a pattern to detect the specific information of your data. Select Validate to confirm the syntax of your entry.
Select Done to create the custom classification.
The new customization is captured in the next scheduled scan. To view results, see Generate compliance reports.
