Cloud Volumes ONTAP
Azure
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Supported default configurations for Cloud Volumes ONTAP
Contributors netapp-manini netapp-rlithman netapp-bcammett netapp-driley
Understanding how Cloud Volumes ONTAP is configured by default can help you set up and administer your systems, especially if you are familiar with ONTAP because the default setup for Cloud Volumes ONTAP is different than ONTAP.
Default setup
  • BlueXP creates one data-serving storage VM when it deploys Cloud Volumes ONTAP. Some configurations support additional storage VMs. Learn more about managing storage VMs.
    Starting with the BlueXP 3.9.5 release, logical space reporting is enabled on the initial storage VM. When space is reported logically, ONTAP reports the volume space such that all the physical space saved by the storage efficiency features are also reported as used. For information about inline storage efficiency features, refer to the knowledge base article KB: What Inline Storage Efficiency features are supported with CVO?
  • BlueXP automatically installs the following ONTAP feature licenses on Cloud Volumes ONTAP:
    • CIFS
    • FlexCache
    • FlexClone
    • iSCSI
    • Multi-tenant Encryption Key Management (MTEKM), starting with Cloud Volumes ONTAP 9.12.1 GA
    • NetApp Volume Encryption (only for bring your own license (BYOL) or registered pay-as-you-go (PAYGO) systems)
    • NFS
    • ONTAP S3
      Starting with Cloud Volumes ONTAP 9.9.1 in Azure
    • SnapMirror
    • SnapRestore
    • SnapVault
  • Several network interfaces are created by default:
    • A cluster management LIF
    • An intercluster LIF
    • An SVM management LIF on HA systems in Azure
    • A node management LIF
    • An iSCSI data LIF
    • A CIFS and NFS data LIF
      Note LIF failover is disabled by default for Cloud Volumes ONTAP due to cloud provider requirements. Migrating a LIF to a different port breaks the external mapping between IP addresses and network interfaces on the instance, making the LIF inaccessible.
  • Cloud Volumes ONTAP sends configuration backups to the Connector using HTTP.
    The backups are accessible from http://ipaddress/occm/offboxconfig/ where ipaddress is the IP address of the Connector host.
    You can use the backups for reconfiguring your Cloud Volumes ONTAP system. For more information about configuration backups, refer to the ONTAP documentation.
  • BlueXP sets a few volume attributes differently than other management tools (ONTAP System Manager or the ONTAP CLI, for example).
    The following table lists the volume attributes that BlueXP sets differently from the defaults:
    Attribute Value set by BlueXP
    Autosize mode
    grow
    Maximum autosize
    1,000 percent
    Note The BlueXP Organization or Account admin can modify this value from the Settings page.
    Security style
    NTFS for CIFS volumes
    UNIX for NFS volumes
    Space guarantee style
    none
    UNIX permissions (NFS only)
    777
    For information about these attributes, refer to ONTAP volume create man page.
Internal disks for system data
In addition to the storage for user data, BlueXP also purchases cloud storage for system data.
Azure (single node)
  • Three Premium SSD disks:
    • One 10 GiB disk for boot data
    • One 140 GiB disk for root data
    • One 512 GiB disk for NVRAM
      If the virtual machine that you chose for Cloud Volumes ONTAP supports Ultra SSDs, then the system uses a 32 GiB Ultra SSD for NVRAM, rather than a Premium SSD.
  • One 1024 GiB Standard HDD disk for saving cores
  • One Azure snapshot for each boot disk and root disk
  • Every disk by default in Azure is encrypted at rest.
    If the virtual machine that you chose for Cloud Volumes ONTAP supports Premium SSD v2 Managed Disk as data disks, the system uses a 32 GiB Premium SSD v2 Managed Disk for NVRAM, and another one as the root disk.
Azure (HA pair)
HA pairs with page blob
  • Two 10 GiB Premium SSD disks for the boot volume (one per node)
  • Two 140 GiB Premium Storage page blobs for the root volume (one per node)
  • Two 1024 GiB Standard HDD disks for saving cores (one per node)
  • Two 512 GiB Premium SSD disks for NVRAM (one per node)
    Note Snapshots are created automatically upon reboot.
HA pairs with shared managed disks in multiple availability zones
  • Two 512 GiB Premium SSD disks for the root volume (one per node)
HA pairs with shared managed disks in single availability zones
  • Two 512 GiB Premium SSD Shared Managed disks for the root volume (one per node)
  • Two 512 GiB Premium SSD Managed disks for NVRAM (one per node)
If your virtual machine supports Premium SSD v2 Managed Disks as data disks, it uses 32 GiB Premium SSD v2 Managed Disks for NVRAM and 512 GiB Premium SSD v2 Shared Managed disks for the root volume.
You can deploy HA pairs in a single single availability zone and use Premium SSD v2 Managed Disks when the following conditions are fulfilled:
Where the disks reside
BlueXP lays out the storage as follows:
  • Boot data resides on a disk attached to the instance or virtual machine.
    This disk, which contains the boot image, is not available to Cloud Volumes ONTAP.
  • Root data, which contains the system configuration and logs, resides in aggr0.
  • The storage virtual machine (SVM) root volume resides in aggr1.
  • Data volumes also reside in aggr1.
