Cloud Volumes ONTAP
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Learn about support for AWS Elastic Volumes with Cloud Volumes ONTAP
Contributors netapp-ahibbard netapp-manini
Support for the Amazon EBS Elastic Volumes feature with a Cloud Volumes ONTAP aggregate provides better performance and additional capacity, while enabling the NetApp Console to automatically increase the underlying disk capacity as needed.
Benefits
  • Dynamic disk growth
    The Console can dynamically increase the size of disks while Cloud Volumes ONTAP is running and while disks are still attached.
  • Better performance
    Aggregates that are enabled with Elastic Volumes can have up to eight disks that are equally utilized across two RAID groups. This configuration provides more throughput and consistent performance.
  • Larger aggregates
    Support for eight disks provides a maximum aggregate capacity of 128 TiB. These limits are higher than the six disk limit and 96 TiB limit for aggregates that aren't enabled with the Elastic Volumes feature.
    Note that total system capacity limits remain the same.
Supported configurations
The Amazon EBS Elastic Volumes feature is supported with specific Cloud Volumes ONTAP versions and specific EBS disk types.
The Elastic Volumes feature is supported with new Cloud Volumes ONTAP systems created from version 9.11.0 or later. The feature is not supported with existing Cloud Volumes ONTAP systems that were deployed prior to 9.11.0.
For example, the Elastic Volumes feature is not supported if you created a Cloud Volumes ONTAP 9.9.0 system and then later upgraded that system to version 9.11.0. It must be a new system deployed using version 9.11.0 or later.
EBS disk types
The Elastic Volumes feature is automatically enabled at the aggregate level when using General Purpose SSDs (gp3) or Provisioned IOPS SSDs (io1). The Elastic Volumes feature is not supported with aggregates that use any other disk type.
Required AWS permissions
Starting with the 3.9.19 release, the Console agent requires the following permissions to enable and manage the Elastic Volumes feature on a Cloud Volumes ONTAP aggregate:
  • ec2:DescribeVolumesModifications
  • ec2:ModifyVolume
These permissions are included in the policies provided by NetApp
How support for Elastic Volumes works
An aggregate that has the Elastic Volumes feature enabled is comprised of one or two RAID groups. Each RAID group has four identical disks that have the same capacity. Here's an example of a 10 TiB aggregate that has four disks that are 2.5 TiB each:
A conceptual image that shows an aggregate and a RAID group that is comprised of four disks of equal size.
When the Console creates an aggregate, it starts with one RAID group. If additional capacity is needed, it grows the aggregate by increasing the capacity of all disks in the RAID group by the same amount. The capacity increase is either a minimum of 256 GiB or 10% of the aggregate's size.
For example, if you have a 1 TiB aggregate, each disk is 250 GiB. 10% of the aggregate’s capacity is 100 GiB. That’s lower than 256 GiB, so the size of the aggregate is increased by the 256 GiB minimum (or 64 GiB for each disk).
The Console increases the size of the disks while the Cloud Volumes ONTAP system is running and while the disks are still attached. The change is non-disruptive.
If an aggregate reaches 64 TiB (or 16 TiB on each disk), the Console creates a second RAID group for additional capacity. This second RAID group works just like the first one: it has four disks that have the exact same capacity and it can grow up to 64 TiB. That means an aggregate can have a maximum capacity of 128 TiB.
Here's an example of an aggregate with two RAID groups. The capacity limit has been reached on the first RAID group, while the disks in the second RAID group have plenty of free space.
A conceptual image that shows an aggregate and two RAID groups that are both comprised of four disks of equal size.
What happens when you create a volume
If you create a volume that uses gp3 or io1 disks, the Console creates the volume on an aggregate as follows:
  • If there is an existing gp3 or io1 aggregate that has Elastic Volumes enabled, the Console creates the volume on that aggregate.
  • If there are multiple gp3 or io1 aggregates that have Elastic Volumes enabled, the Console creates the volume on the aggregate that requires the least amount of resources.
  • If the system only has gp3 or io1 aggregates that aren't enabled for Elastic Volumes, then the volume is created on that aggregate.
    Note
    While this scenario is unlikely, it's possible in two cases:
    • You explicitly disabled the Elastic Volumes feature when creating an aggregate from the API.
    • You created a new Cloud Volumes ONTAP system from the user interface, in which case the Elastic Volumes feature is disabled on the initial aggregate. Review Limitations below to learn more.
  • If no existing aggregates have enough capacity, the Console creates the aggregate with Elastic Volumes enabled and then creates the volume on that new aggregate.
    The size of the aggregate is based on the requested volume size plus an additional 10% capacity.
Capacity Management Mode
The Capacity Management Mode for a Console agent works with Elastic Volumes similar to how it works with other types of aggregates:
  • When Automatic mode is enabled (this is the default setting), the Console automatically increases the size of aggregates if additional capacity is needed.
  • If you change the capacity management mode to Manual, the Console asks for your approval to purchase additional capacity.
Limitations
Increasing the size of an aggregate can take up to 6 hours. During that time, the Console can't request any additional capacity for that aggregate.
How to work with Elastic Volumes
You can perform these tasks with Elastic Volumes:
  • Create a new system that has Elastic Volumes enabled on the initial aggregate when using gp3 or io1 disks
  • Create a new volume on an aggregate that has Elastic Volumes enabled
    If you create a volume that uses gp3 or io1 disks, the Console automatically creates the volume on an aggregate that has Elastic Volumes enabled. For more details, refer to What happens when you create a volume.
  • Create a new aggregate that has Elastic Volumes enabled
    Elastic Volumes is automatically enabled on new aggregates that use gp3 or io1 disks, as long as the Cloud Volumes ONTAP system was created from version 9.11.0 or later.
    When you create the aggregate, the Console prompts you for the aggregate's capacity size. This is different than other configurations where you choose a disk size and number of disks.
    The following screenshot shows an example of a new aggregate comprised of gp3 disks.
    A screenshot of the Aggregate Disks screen for a gp3 disk where you enter the aggregate size in TiB.
  • Identify aggregates that have Elastic Volumes enabled
    When you go to the Advanced Allocation page, you can identify whether the Elastic Volumes feature is enabled on an aggregate. In the following example, aggr1 has Elastic Volumes enabled.
    Screenshot that shows two aggregates where one has a field with the text Elastic Volumes Enabled.
  • Add capacity to an aggregate
    While the Console automatically adds capacity to aggregates as needed, you can manually increase the capacity yourself.
  • Replicate data to an aggregate that has Elastic Volumes enabled
    If the destination Cloud Volumes ONTAP system supports Elastic Volumes, a destination volume will be placed on an aggregate that has Elastic Volumes enabled (as long as you choose a gp3 or io1 disk).
