Cloud Volumes ONTAP
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Manage aggregates for Cloud Volumes ONTAP clusters
Contributors netapp-driley netapp-bcammett netapp-manini netapp-rlithman
Manage aggregates yourself by adding disks, viewing information about the aggregates, and by deleting them.
Caution All disks and aggregates must be created and deleted directly from BlueXP. You should not perform these actions from another management tool. Doing so can impact system stability, hamper the ability to add disks in the future, and potentially generate redundant cloud provider fees.
Before you begin
If you want to delete an aggregate, you must have first deleted the volumes in the aggregate.
About this task
If an aggregate is running out of space, you can move volumes to another aggregate by using ONTAP System Manager.
Steps
  1. From the left navigation menu, select Storage > Canvas.
  2. On the Canvas page, double-click the Cloud Volumes ONTAP working environment on which you want to manage aggregates.
  3. In the working environment, click the Aggregates tab.
  4. On the Aggregates tab, navigate to the desired title and then click the …​ (ellipses icon).
    A screenshot of the Aggregates menu options.
  5. Manage your aggregates:
    Task Action
    View information about an aggregate
    Under the …​ (ellipses icon) menu, click View aggregate details.
    Create a volume on a specific aggregate
    Under the …​ (ellipses icon) menu, click Add volume.
    Add disks to an aggregate
    1. Under the …​ (ellipses icon) menu, click Add disks.
    2. Select the number of disks that you want to add and click Add.
      Tip All disks in an aggregate must be the same size.
    Increase the capacity of an aggregate that supports Amazon EBS Elastic Volumes
    1. Under the …​ (ellipses icon) menu, click Increase capacity.
    2. Enter the additional capacity that you'd like to add and then click Increase.
      Note that you must increase the capacity of the aggregate by a minimum of 256 GiB or 10% of the aggregate's size.
      For example, if you have a 1.77 TiB aggregate, 10% is 181 GiB. That’s lower than 256 GiB, so the size of the aggregate must in increased by the 256 GiB minimum.
    Delete an aggregate
    1. Select an aggregate tile that does not contain any volumes click the …​ (ellipses icon) > Delete.
    2. Click Delete again to confirm.
