Paying for sync relationships after your free trial ends
There are two ways to pay for sync relationships after your 14-day free trial ends. The first option is to subscribe from AWS or Azure to pay-as-you-go or to pay annually. The second option is to purchase licenses directly from NetApp.
You can subscribe from either the AWS Marketplace or the Azure Marketplace. You can’t subscribe from both.
You have the option to use licenses from NetApp with a Marketplace subscription. For example, if you have 25 sync relationships, you can pay for the first 20 sync relationships using a license and then pay-as-you-go from AWS or Azure with the remaining 5 sync relationships.
If you don’t immediately pay after your free trial ends, you won’t be able to create any additional relationships. Existing relationships are not deleted, but you cannot make any changes to them until you subscribe or enter a license.
Licenses should be managed through BlueXP copy and sync or the applicable website and not through a digital wallet.
Subscribing from AWS
AWS enables you to pay-as-you-go or to pay annually.
Click Sync > Licensing.
Select AWS
Click Subscribe and then click Continue.
Subscribe from the AWS Marketplace, and then log back in to the BlueXP copy and sync service to complete the registration.
The following video shows the process:
Click Continue to Subscribe.
Select your contract options and click Create contract.
Subscribing from Azure
Azure enables you to pay-as-you-go or to pay annually.
An Azure user account that has Contributor or Owner permissions in the relevant subscription.
Select Azure.
In the Azure portal, click Create, select your options, and click Subscribe.
Select Monthly to pay by the hour, or Yearly to pay for a year up front.
When deployment is complete, click the name of the SaaS resource in the notification pop-up.
Click Configure Account to return to BlueXP copy and sync.
Purchasing licenses from NetApp and adding them to BlueXP copy and sync
To pay for your sync relationships up front, you must purchase one or more licenses and add them to the BlueXP copy and sync service.
You’ll need the serial number for your license and the user name and password for the NetApp Support Site account that the license is associated with.
Purchase a license by contacting NetApp.
In BlueXP, click Sync > Licensing.
Click Add License and add the required information:
Enter the serial number.
Select the NetApp Support Site account that is associated with the license that you’re adding:
If your account was already added to BlueXP, select it from the drop-down list.
If your account wasn’t added yet, click Add NSS Credentials, enter the user name and password, click Register, and then select it from the drop-down list.
Click Add.
Updating a license
If you extended a BlueXP copy and sync license that you purchased from NetApp, the new expiration date won’t update automatically in BlueXP copy and sync. You need to add the license again to refresh the expiration date. Licenses should be managed through BlueXP copy and sync or the applicable website and not through a digital wallet.
Select the NetApp Support Site account that is associated with the license that you’re adding.
Click Add.
BlueXP copy and sync updates the existing license with the new expiration date.
