BlueXP digital wallet
Manage Keystone subscriptions
Contributors netapp-bcammett netapp-tonias
Manage your Keystone subscriptions from the BlueXP digital wallet by enabling subscriptions for use with Cloud Volumes ONTAP and by requesting changes to the committed capacity for your subscription's service levels. Requesting additional capacity for a service level provides more storage for on-premises ONTAP clusters or for Cloud Volumes ONTAP systems.
NetApp Keystone is a flexible pay-as-you-grow subscription-based service that delivers a hybrid cloud experience for customers who prefer OpEx to CapEx or leasing.
Authorize your account
Before you can use and manage Keystone subscriptions in BlueXP, you need to contact NetApp to authorize your BlueXP user account with your Keystone subscriptions.
Steps
  1. From the BlueXP navigation menu, select Governance > Digital wallet.
  2. Select Keystone Subscriptions.
  3. If you see the Welcome to NetApp Keystone page, send an email to the address listed on the page.
    A NetApp representative will process your request by authorizing your user account to access the subscriptions.
  4. Come back to the Keystone Subscriptions tab to view your subscriptions.
    A screenshot that shows a list of Keystone Subscriptions.
After NetApp authorizes your account, you can link Keystone subscriptions for use with Cloud Volumes ONTAP. This action enables users to select the subscription as the charging method for new Cloud Volumes ONTAP systems.
Steps
  3. For the subscription that you want to link, click An icon that is three side-by-side dots and select Link.
    A screenshot that shows the link option for a subscription.
Result
The subscription is now linked to your BlueXP organization or account and available to select when creating a Cloud Volumes ONTAP working environment.
Request more or less committed capacity
If you want to change the committed capacity for your subscription's service levels, you can send a request to NetApp directly from BlueXP. Requesting additional capacity for a service level provides more storage for on-premises clusters or for Cloud Volumes ONTAP systems.
Steps
  3. For the subscription that you want adjust the capacity, click An icon that is three side-by-side dots and select View detail and edit.
  4. Enter the requested committed capacity for one or more subscriptions.
    A screenshot that shows the ability to request a change to the committed capacity for a subscription.
  5. Scroll down, enter any additional details for the request, and then click Submit.
Result
Your request creates a ticket in NetApp's system for processing.
Monitor usage
The BlueXP digital advisor dashboard enables you to monitor Keystone subscription usage and to generate reports.
If you no longer want to use a Keystone subscription with BlueXP, you can unlink the subscription. Note that you can only unlink a subscription that isn't attached to an existing Cloud Volumes ONTAP subscription.
Steps
  2. Select Keystone.
  3. For the subscription that you want to unlink, click An icon that is three side-by-side dots and select Unlink.
Result
The subscription is unlinked from your BlueXP organization or account and no longer available to select when creating a Cloud Volumes ONTAP working environment.
