Discover E-Series systems
BlueXP can discover the E-Series systems in your on-premises environment. Adding E-Series systems to BlueXP enables you to get a complete view of the data across your hybrid multicloud.
Organization admin, Folder or project admin, Storage admin, or System health specialist. Learn about BlueXP access roles.
You need the following:
A Connector installed in a cloud provider or on your premises, with network connectivity to the E-Series system. You must have the Org admin role to create a Connector.
The domain name or IP address of the storage system controller.
Admin credentials for the E-Series system.
One of the following BlueXP access roles: Org admin, Folder or project admin, or Storage admin.
From the navigation menu, select Storage > Canvas.
From the Canvas, select Add Working Environment and select On-Premises.
Next to E-Series, select Discover.
If you're prompted, create a Connector.
Refer to the link above for more details.
On the E-Series Cluster Details page, enter the domain name or IP address of the storage system controller, admin credentials for the system, and then select Add.
BlueXP discovers the E-Series system and adds it as a working environment on the Canvas.
