Remove an E-Series working environment
Contributors netapp-tonias netapp-bcammett
Remove an E-Series working environment if you no longer want to manage it from BlueXP.
Required BlueXP role
Organization admin, Folder or project admin, or Storage admin. Learn about BlueXP access roles.
Removing the working environment doesn't affect the E-Series system. You can rediscover it from BlueXP at any time.
Steps
  1. From the navigation menu, select Storage > Canvas.
  2. On the Canvas page, select the E-Series working environment.
  3. Select the menu icon and select Remove from Workspace.
    A screenshot of the Remove from Workspace option that is available in the top right menu of the working environment.
  4. Select Remove to confirm.
