Set reminders to check again
Rather than add capacity or tier cold data, you can choose no action required at this time and set reminders for yourself to check again after 30, 60, or 90 days.
Steps
From the BlueXP left navigation, select Governance > Economic efficiency > Capacity planning.
Select Evaluate Storage Options for the asset.
Select No action needed.
Choose when you want to be notified again of a potential low-capacity issue: 30, 60, or 90 days.
Select Save.
Result
After that time elapses, the risk appears again in the list of risks.
