Security group rules for FSx for ONTAP
BlueXP creates AWS security groups that include the inbound and outbound rules that BlueXP and FSx for ONTAP need to operate successfully. You might want to refer to the ports for testing purposes or if you need to use your own.
Rules for FSx for ONTAP
The FSx for ONTAP security group requires both inbound and outbound rules. This diagram illustrates FSx for ONTAP networking configuration and security group requirements.
A diagram of FSx for ONTAP security group configuration.
Before you begin
You need to locate the security groups associated with the ENIs using the AWS Management Console.
Steps
  1. Open the FSx for ONTAP file system in the AWS Management Console and click the file system ID link.
    A screenshot of the FSx file system ID in AWS Management Console.
  2. On the Network & security tab, click the network interface ID for the preferred or standby subnet.
    A screenshot of the FSx for ONTAP ENI ID.
  3. Click the security group in the network interface table or the Details section for the network interface.
    A screenshot of the FSx for ONTAP security group ID.
Inbound rules
Protocol Port Purpose
All ICMP
All
Pinging the instance
HTTPS
443
Access from the Connector to fsxadmin management LIF to send API calls to FSx
SSH
22
SSH access to the IP address of the cluster management LIF or a node management LIF
TCP
111
Remote procedure call for NFS
TCP
139
NetBIOS service session for CIFS
TCP
161-162
Simple network management protocol
TCP
445
Microsoft SMB/CIFS over TCP with NetBIOS framing
TCP
635
NFS mount
TCP
749
Kerberos
TCP
2049
NFS server daemon
TCP
3260
iSCSI access through the iSCSI data LIF
TCP
4045
NFS lock daemon
TCP
4046
Network status monitor for NFS
TCP
10000
Backup using NDMP
TCP
11104
Management of intercluster communication sessions for SnapMirror
TCP
11105
SnapMirror data transfer using intercluster LIFs
UDP
111
UDP
161-162
UDP
635
NFS mount
UDP
2049
NFS server daemon
UDP
4045
NFS lock daemon
UDP
4046
UDP
4049
NFS rquotad protocol
Outbound rules
The predefined security group for FSx for ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for FSx for ONTAP includes the following outbound rules.
All ICMP
All
All outbound traffic
All TCP
All
All UDP
All
Advanced outbound rules
You do not need to open specific ports for the mediator or between nodes in FSx for ONTAP.
Note The source is the interface (IP address) on the FSx for ONTAP system.
Service Protocol Port Source Destination Purpose
Active Directory
TCP
88
Node management LIF
Active Directory forest
Kerberos V authentication
UDP
137
Node management LIF
NetBIOS name service
UDP
138
Node management LIF
NetBIOS datagram service
TCP
139
Node management LIF
TCP & UDP
389
Node management LIF
LDAP
TCP
445
Node management LIF
TCP
464
Node management LIF
Kerberos V change & set password (SET_CHANGE)
UDP
464
Node management LIF
Kerberos key administration
TCP
749
Node management LIF
Kerberos V change & set Password (RPCSEC_GSS)
TCP
88
Data LIF (NFS, CIFS, iSCSI)
UDP
137
Data LIF (NFS, CIFS)
UDP
138
TCP
139
TCP & UDP
389
LDAP
TCP
445
TCP
464
UDP
464
TCP
749
Kerberos V change & set password (RPCSEC_GSS)
Backup to S3
TCP
5010
Intercluster LIF
Backup endpoint or restore endpoint
Back up and restore operations for the Backup to S3 feature
DHCP
UDP
68
Node management LIF
DHCP
DHCP client for first-time setup
DHCPS
UDP
67
Node management LIF
DHCP
DHCP server
DNS
UDP
53
Node management LIF and data LIF (NFS, CIFS)
DNS
DNS
NDMP
TCP
18600–18699
Node management LIF
Destination servers
NDMP copy
SMTP
TCP
25
Node management LIF
Mail server
SMTP alerts, can be used for AutoSupport
SNMP
TCP
161
Node management LIF
Monitor server
Monitoring by SNMP traps
UDP
161
Node management LIF
Monitor server
TCP
162
Node management LIF
Monitor server
UDP
162
Node management LIF
Monitor server
SnapMirror
TCP
11104
Intercluster LIF
ONTAP intercluster LIFs
TCP
11105
Intercluster LIF
Syslog
UDP
514
Node management LIF
Syslog server
Syslog forward messages
Rules for the Connector
The security group for the Connector requires both inbound and outbound rules.
Inbound rules
SSH
22
Provides SSH access to the Connector host
HTTP
80
Provides HTTP access from client web browsers to the local user interface and connections from BlueXP classification instance
HTTPS
443
Provides HTTPS access from client web browsers to the local user interface
TCP
3128
Provides the BlueXP classification instance with internet access, if your AWS network doesn’t use a NAT or proxy
Outbound rules
The predefined security group for the Connector opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for the Connector includes the following outbound rules.
All TCP
All
All UDP
All
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the Connector.
Note The source IP address is the Connector host.
Service Protocol Port Destination Purpose
Active Directory
TCP
88
TCP
139
TCP
389
LDAP
TCP
445
TCP
464
TCP
749
Active Directory Kerberos V change & set password (RPCSEC_GSS)
UDP
137
UDP
138
UDP
464
API calls and AutoSupport
HTTPS
443
Outbound internet and ONTAP cluster management LIF
API calls to AWS and ONTAP, and sending AutoSupport messages to NetApp
API calls
TCP
8088
Backup to S3
API calls to Backup to S3
DNS
UDP
53
DNS
Used for DNS resolve by BlueXP
HTTP
80
BlueXP classification for Cloud Volumes ONTAP
