Learn about on-premises ONTAP cluster management in BlueXP
BlueXP can discover the ONTAP clusters running on AFF/FAS controllers and ONTAP Select. Adding on-premises ONTAP systems to BlueXP enables you to manage all of your storage and data assets from a single interface.
Features
Manage NFS and CIFS volumes
Access ONTAP System Manager for any managed cluster through BlueXP
Get health and performance observability with BlueXP analysis and control
Use BlueXP services to replicate, back up, scan, classify, and tier data
View hardware and software contract status information in the BlueXP digital wallet
Cost
A cost might be associated, but it depends on the following:
Whether you deploy a Connector to discover and manage your clusters.
You can install the Connector in the cloud or on your premises. Costs are incurred when you install a Connector in the cloud.
Whether you use BlueXP services such as backup and recovery, tiering, and classification.
