Remove an on-prem ONTAP working environment
Remove an on-premises ONTAP working environment if you no longer want to manage it from BlueXP.
Required BlueXP role:
Organization admin, Folder or project admin, or Storage admin. Learn about BlueXP access roles.
Removing the working environment doesn't affect the ONTAP cluster. You can rediscover it from BlueXP at any time.
Steps
On the Canvas page, select the on-premises ONTAP working environment.
Select the menu icon and select Remove from workspace.
Select Remove to confirm.
