Associate a BlueXP Connector with other folders and projects
When an _Organization admin_ creates a Connector, it is automatcially associated with currently selected project within the organization. Although someone with the _Organization admin_ can access to that Connector from anywhere in the organization. Other members in your organization can only access that Connector from the project in which it was created, unless you associate that Connector with other projects.
You should understand how Connector association works. Learn about using Connectors with BlueXP IAM.
When a Folder or project admin views the Connectors page, the page displays all Connectors in the organization. However, a member with this role can only view and associate Connectors with the folders and projects for which they have permissions. Learn more about the actions that a Folder or project admin can complete.
In the upper right of the BlueXP console, select
> Identity & Access Management.
Select Connectors.
From the table, find the Connector that you want to associate.
Use the search above the table to find a specific Connector or filter the table by resource hierarchy.
To view the folders and projects linked to the Connector, select
and then select View details.
BlueXP displays details about the folders and projects that the Connector is associated with.
Select Associate to folder or project.
Select a folder or project and then select Accept.
To associate the Connector with an additional folder or project, select Add a folder or project and then select the folder or project.
Select Associate Connector.
If you want to associate the resources that the Connector manages with the same folders and projects, you can do so from the Resources page.
