BlueXP setup and administration
Enforce ONTAP permissions for ONTAP Advanced View (ONTAP System Manager)
Contributors netapp-tonias
By default, the Connector credentials allow users to access the Advanced View (ONTAP System Manager). You can prompt users for their ONTAP credentials instead. This ensures that a user's ONTAP permissions are applied when they work with ONTAP clusters in both Cloud Volumes ONTAP and ONTAP on-premises clusters.
Note You must have the Organization admin role to edit Connector settings.
Steps
  1. Select the Connector drop-down from the BlueXP header.
  2. Select Manage Connectors.
  3. Select the action menu in the row that corresponds to the Connector you want to edit.
  4. Expand the Force Credentials option.
  5. Select the checkbox to enable the Force Credentials option and then select Save.
  6. Check if the Force Credentials option is enabled.
    Screenshot showing that force credentials is on
