Troubleshoot the Connector
To troubleshoot issues with the Connector, you can work with NetApp Support who might ask for your system ID, Connector version, or the latest AutoSupport messages. You can also view the NetApp Knowledge Base to troubleshoot issues yourself.
Find the system ID for a Connector
To help you get started, your NetApp representative might ask you for the system ID of your Connector. The ID is typically used for licensing and troubleshooting purposes.
In the upper right of the BlueXP console, select the Help icon.
Select Support > BlueXP Connector.
The system ID appears at the top of the page.
Example
View a Connector's version
You can view the version of your Connector to verify that the Connector automatically upgraded to the latest release or because you need to share it with your NetApp representative.
The version displays at the top of the page.
Download or send an AutoSupport message
If you're having problems, NetApp personnel might ask you to send an AutoSupport message to NetApp support for troubleshooting purposes.
In the upper right of the BlueXP console, select the Help icon, and select Support.
Select BlueXP Connector.
Depending on how you need to send the information to NetApp support, choose one of the following options:
Select the option to download the AutoSupport message to your local machine. You can then send it to NetApp Support using a preferred method.
Select Send AutoSupport to directly send the message to NetApp Support.
BlueXP may take up to five hours to send AutoSupport messages due to load balancing. For urgent communication, download the file and send it manually.
Fix download failures when using a Google Cloud NAT gateway
The Connector automatically downloads software updates for Cloud Volumes ONTAP. The download can fail if your configuration uses a Google Cloud NAT gateway. You can correct this issue by limiting the number of parts that the software image is divided into. This step must be completed by using the BlueXP API.
Submit a PUT request to /occm/config with the following JSON as body:
{ "maxDownloadSessions": 32 }
The value for maxDownloadSessions can be 1 or any integer greater than 1. If the value is 1, then the downloaded image will not be divided.
Note that 32 is an example value. The value that you should use depends on your NAT configuration and the number of sessions that you can have simultaneously.
