View and update StorageGRID certificates in BlueXP
A management interface certificate is required on your StorageGRID system before you discover the system from BlueXP. The certificate provides a secure connection between BlueXP and StorageGRID. Since certificates can expire, you occasionally might need to view the status or update a certificate.
View the status of a management interface certificate
View the status of the management interface certificate for a StorageGRID system to verify that the certificate is still valid.
Steps
  1. From the navigation menu, select Storage > Canvas.
  2. On the Canvas page, select the StorageGRID working environment.
  3. From the standard view, check the status of the user approved certificate at the bottom of the Information pane on the right side of the page.
    Note The certificate status is refreshed once every 24 hours.
    A screenshot of the of the Information pane in the working environment.
Update the management interface certificate
If the status of your management interface certificate is not valid or you receive a notification that your certificate has expired, you will need to update it so BlueXP can connect to StorageGRID.
Steps
  1. Go to your on-premises Grid Manager in StorageGRID and follow the instructions for Installing a management interface certificate on StorageGRID.
  2. From the BlueXP navigation menu, select Storage > Canvas.
  3. On the Canvas page, select the StorageGRID working environment.
  4. Select the more options icon (circle with three vertical dots).
    A screenshot of the of the update menu.
  5. Select Update certificate.
  6. On the Approve certificate page, select Approve Certificate to use the updated certificate.
    A screenshot that shows the Approve Certificate screen that appears during discovery of a StorageGRID system
