Supported Azure Blob access tiers and regions
BlueXP tiering supports two access tiers and most regions.
When you set up data tiering to Azure from your on-premises ONTAP systems, BlueXP tiering automatically uses the Hot access tier for your inactive data. BlueXP tiering can apply a lifecycle rule so the data transitions from the Hot access tier to the Cool access tier after a certain number of days.
If you do not choose the Cool access tier, then the data remains in the Hot access tier and no rules are applied.
When you configure a BlueXP tiering lifecycle rule, you must not configure any lifecycle rules when setting up the container in your Azure account.
Supported Azure regions
BlueXP tiering is supported in all Azure Regions except for China, where Microsoft Azure operated by 21Vianet.
