Default configuration for Cloud Volumes ONTAP
Understanding how Cloud Volumes ONTAP is configured by default can help you set up and administer your systems, especially if you are familiar with ONTAP because the default setup for Cloud Volumes ONTAP is different than ONTAP.
Default setup
Cloud Manager creates one data-serving storage VM when it deploys Cloud Volumes ONTAP. Some configurations support additional storage VMs. Learn more about managing storage VMs.
Starting with the Cloud Manager 3.9.5 release, logical space reporting is enabled on the initial storage VM. When space is reported logically, ONTAP reports the volume space such that all the physical space saved by the storage efficiency features are also reported as used.
Cloud Manager automatically installs the following ONTAP feature licenses on Cloud Volumes ONTAP:
CIFS
FlexCache
FlexClone
iSCSI
NetApp Volume Encryption (only for BYOL or registered PAYGO systems)
NFS
SnapMirror
SnapRestore
SnapVault
Several network interfaces are created by default:
A cluster management LIF
An intercluster LIF
An SVM management LIF on HA systems in Azure
An SVM management LIF on HA systems in Google Cloud
An SVM management LIF on single node systems in AWS
A node management LIF
In Google Cloud, this LIF is combined with the intercluster LIF.
An iSCSI data LIF
A CIFS and NFS data LIF
LIF failover is disabled by default for Cloud Volumes ONTAP due to cloud provider requirements. Migrating a LIF to a different port breaks the external mapping between IP addresses and network interfaces on the instance, making the LIF inaccessible.
Cloud Volumes ONTAP sends configuration backups to the Connector using HTTPS.
The backups are accessible from https://ipaddress/occm/offboxconfig/ where ipaddress is the IP address of the Connector host.
Cloud Manager sets a few volume attributes differently than other management tools (System Manager or the CLI, for example).
The following table lists the volume attributes that Cloud Manager sets differently from the defaults:
Attribute Value set by Cloud Manager Autosize mode
grow
Maximum autosize
1,000 percent
The Account Admin can modify this value from the Settings page. Security style
NTFS for CIFS volumes
UNIX for NFS volumesSpace guarantee style
none
UNIX permissions (NFS only)
777
See the volume create man page for information about these attributes.
Internal disks for system data
In addition to the storage for user data, Cloud Manager also purchases cloud storage for system data.
AWS
Three disks per node for boot, root, and core data:
45 GiB io1 disk for boot data
140 GiB gp3 disk for root data
540 GiB gp2 disk for core data
One EBS snapshot for each boot disk and root disk
For HA pairs, one EBS volume for the Mediator instance, which is approximately 8 GiB
When you enable data encryption in AWS using the Key Management Service (KMS), the boot and root disks for Cloud Volumes ONTAP are encrypted, as well. This includes the boot disk for the mediator instance in an HA pair. The disks are encrypted using the CMK that you select when you create the working environment.
In AWS, NVRAM is on the boot disk. |
Azure (single node)
Three Premium SSD disks:
One 10 GiB disk for boot data
One 140 GiB disk for root data
One 512 GiB disk for NVRAM
If the virtual machine that you chose for Cloud Volumes ONTAP supports Ultra SSDs, then the system uses a 32 GiB Ultra SSD for NVRAM, rather than a Premium SSD.
One 1024 GiB Standard HDD disk for saving cores
One Azure snapshot for each boot disk and root disk
Boot and root disks are encrypted by default.
Azure (HA pair)
Two 10 GiB Premium SSD disks for the boot volume (one per node)
Two 140 GiB Premium Storage page blobs for the root volume (one per node)
Two 1024 GiB Standard HDD disks for saving cores (one per node)
Two 512 GiB Premium SSD disks for NVRAM (one per node)
Google Cloud (single node)
One 10 GiB SSD persistent disk for boot data
One 64 GiB SSD persistent disk for root data
One 500 GiB SSD persistent disk for NVRAM
One 315 GiB Standard persistent disk for saving cores
Snapshots for boot and root data
Google Cloud (HA pair)
Two 10 GiB SSD persistent disks for boot data
Four 64 GiB SSD persistent disk for root data
Two 500 GiB SSD persistent disk for NVRAM
Two 315 GiB Standard persistent disk for saving cores
One 10 GiB Standard persistent disk for mediator data
Where the disks reside
Cloud Manager lays out the storage as follows:
Boot data resides on a disk attached to the instance or virtual machine.
This disk, which contains the boot image, is not available to Cloud Volumes ONTAP.
Root data, which contains the system configuration and logs, resides in aggr0.
The storage virtual machine (SVM) root volume resides in aggr1.
Data volumes also reside in aggr1.
