Reducing the BlueXP classification scan speed
Data scans have a negligible impact on your storage systems and on your data. However, if you are concerned with even a very small impact, you can configure BlueXP classification to perform "slow" scans.
When enabled, slow scanning is used on all data sources - you can’t configure slow scanning for a single working environment or data source.
The scan speed can’t be reduced when scanning databases. |
Steps
From the bottom of the Configuration page, move the slider to the right to activate slow scanning.
The top of the Configuration page indicates that slow scanning is enabled.
You can disable slow scanning by clicking Disable from this message.
